Transmission fluid temp.... too cold?
Discussion in '2nd Gen Tundras (2007-2013)' started by Ace402, Sep 22, 2018.
  1. Sep 22, 2018 at 10:14 PM
    Ace402
    Ace402 [OP] New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Anyone know how cold is too cold when it comes to transmission fluid. Recent temps for me have been around 190 while the torque converter is locked and as high as 215 while accelerating or decelerating.
    I pinned the transmission thermostat open and now I run 135-155 steady state with spikes up to 175 depending on the ambient temperature.
    Is that too low?
    Rica25 likes this.
  2. Sep 22, 2018 at 11:16 PM
    You will be fine in the SE part of the country. Most transmissions operate between 175-225*F.
    Totally different transmission, but the Allison 1000 in the winter can be running down the road at 77*F. There are a few great threads on transmissions and transmission coolers on this site. Maybe unpin the transmission cooler for the winter if it isn't a real pain for you to do. Return to pinning during the hot/humid months.
    Rica25, NewImprovedRon and Ace402[OP] like this.
  3. Sep 22, 2018 at 11:24 PM
    Ace402
    2011 Tundra 4x4 SR5
    Thanks, I was considering unpinning for the winter
    Rica25 and ColoradoTJ[QUOTED] like this.
  4. Oct 21, 2018 at 11:34 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    After contemplating this for a while, I finally pinned the tranny thermostat open.
    Speculation is that the thermostat doesn't open until 200+ degrees, I'm not comfortable with that.
    With the way our transmission is configured, using engine coolant to warm/regulate the fluid temp, I am not concerned with running too low of a fluid temp.
    Rica25 likes this.
  5. Oct 24, 2018 at 3:52 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    My thermostat on a 2015 opens up at 240-242F. It closes at 225F.
    Rica25 likes this.
  6. Oct 27, 2018 at 8:14 PM
    pitts101
    pitts101 New Member
    2016 TRD Pro
    I like to see mine get above 180 regularly to get rid of any water/condensation
    Rica25 and Johnsonman like this.
  7. Oct 28, 2018 at 10:06 AM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    Sorry if this has already been asked and answered but, how do you pin the transmission thermostat open/closed?
    Rica25 likes this.
  8. Oct 28, 2018 at 11:32 AM
    acmesupply
    No worries. On the side of the transmission you will see a round metal "puck" tucked up on the side. Attached to it is a assembly were a smooth round metal dowel can be pushed into the assembly. You will see two holes on each side that a metal pin can be inserted to pin open the thermostat. Closed is no pin. Open is pinning it open. There is another thread that has pictures of the exact assembly.
    Rica25 likes this.
  9. Oct 28, 2018 at 1:53 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    No argument, just wondering how you determined this. Is this documented some where and if so, where ?
    Implication is that Toyota thinks it’s ok to run 225F all day.
    Greg
    Rica25 likes this.
  10. Oct 28, 2018 at 2:44 PM
    acmesupply
    I have a Ultra Gauge currently and before that a Bluetooth OBDii reader since 2015 that read the TC temp and pan temp. Take a look at my pictures in previous threads. On hot days and unpinned usually towing it will always raise to 240F to 242F and a instant cooling down to 220F to 225F on the TC side and then steadily rise again under load to repeat the process over and over. Pinned it will not do that plus the temps are lower in the first place. The alarm will go off in the center display at 300F and goes off or turns off at @285F.
    Rica25 likes this.
  11. Oct 28, 2018 at 2:45 PM
    acmesupply
  12. Oct 28, 2018 at 3:57 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    I've been pinned open for a week. Tranny temp gauge still runs slightly below the middle. It previously always ran right in the middle.
    I need a scangauge, but I'm really not concerned about being under temp.
    Rica25 likes this.
  13. Oct 28, 2018 at 5:09 PM
    acmesupply
    Yes expect a @30F reduction. Plus under load you can shift lower and the ATF pump will push more fluid through at the higher rpm. I would recommend a Ultra gauge over a scangauge.
    Rica25 likes this.
  14. Oct 28, 2018 at 5:16 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    What model ultra and where did you get it?
    Auto on and off with vehicle?
    Rica25 likes this.
