Transmission Fluid Replacement?
Discussion in '3rd Gen Tundras (2022+)' started by CwickStylz, Jul 25, 2024.
  1. Jul 25, 2024 at 2:39 PM
    CwickStylz
    CwickStylz [OP] New Member
    Andrew
    South Haven, MI
    2022 White Tundra Limited
    So, I am nearing 50,000 miles on my 3rd Gen & can’t seem to find a single thing out there about the process.
    Capacity: 10 speed AJA0E Total Fill 11.7 quarts.
    Capacity: 5.3 quarts Initial Fill.
    From Amsoil website, so my guess is I’m gonna need 12 quarts if I’m gonna do a full fluid swap, but again, just wondering if the process is incredibly straightforward or if it’s different than previous gen Tundras?
    Any feedback or anyone that’s actually done the transmission service at 50K would be greatly appreciated.
  2. Jul 25, 2024 at 5:18 PM
    c&wsinbad
    c&wsinbad Pay yourself FIRST!
    Clark
    Copperas Cove, Texas
    2024 Magnetic Gray Metallic 1794 w-Saddle interior
    BAKFlip MX4
    I haven't done it, so no assist from me. However, most trans don't drain the full capacity; the torque converter retains a significant amount. You may have to do several "drain and fill" events unless you disconnect a trans cooler line and run the engine/trans to force fluid out while simultaneously pumping replacement fluid in (same as flushing?).
  3. Jul 25, 2024 at 7:00 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    At least on my beloved 15 Tacoma. I drained the pan, measure what comes out. Add that amount back. Disconnect the outlet line from the transmission. Take a gallon jug. If 4 qrts came out of the pan, measure 3 qrts in the gallon jug. Start the truck and pump out 3 qrts. Repeat process till the fluid is clean.
  4. Jul 25, 2024 at 9:00 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    It is essentially the same procedure as the years prior. When did a drain and fill on my 3rd gen I got right at a gallon when pulling the plug and fill tube. You can go a step further and disconnect the return line coming back to the transmission from the cooler, dump it into a measuring bucket while then pumping fresh fluid back into the pan. about 2 gallons is remaining in the transmission and converter after the fluid in the pan is done draining. Also, be gentle with the plastic fill tube that screws into the pan.. Easy to break if you get over zelous with it. lightly hand tighten, maybe a few Nm at most.
    Whatever you end up doing, I would recommend either Castrol Trans-max Full-Synthetic or Redline AT6. I had some Redline on hand so used it, but it is pricey and hard to find. Otherwise, I probably would have used Castrol due to the price point. You can check out specifications and read plenty about both at bobistheoilguy.com. Both of these significantly out perform Toyota WS which is an ok formulation and not full synthetic. Fine if you are replacing it often. Not so much if you plan on keeping the truck a while and are not changing the transmission fluid often.
  5. Jul 25, 2024 at 11:05 PM
    Westerntowboss
    Westerntowboss New Member
    I do not believe the new trucks use WS fluid anymore. Are they all still compatible?
  6. Jul 26, 2024 at 4:42 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’ve been told the 10 speed uses WS. Same for the transfer case if you have 4x4.
  7. Jul 26, 2024 at 10:59 AM
    CwickStylz
    Andrew
    South Haven, MI
    So if I’m essentially going to be draining & filling until clean fluid comes out, would you guys say I’d be safe with 2x gallon jugs? I exclusively use Amsoil & sheesh this stuff ain’t cheap! Runs about $73/gallon…they do have a 2.5 gallon jug for $180, so maybe that’s a safer route?
    Thoughts? Feel like I’m putting liquid platinum into my transmission!
    eddiefromcali likes this.
  8. Jul 26, 2024 at 11:10 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I usually do 12 qts and let it be. If you dont have a preferred customer account, PM me...I can hook you up....I'm a dealer
    Tundrastruck91 likes this.
  9. Jul 26, 2024 at 11:27 AM
    nafterclifen
    nafterclifen New Member
    Pocono's, PA
    I can confirm that is what the 2024 Tundra owners manual on the Toyota website says.
  10. Jul 26, 2024 at 11:48 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’ve used Amsoil SS blue cap ATF in a 15 Tacoma and Honda Pilot which take’s DW1. Both shift great. The Tundra will get the same.
    SpilledTheSalt and eddiefromcali like this.
  11. Jul 27, 2024 at 4:02 AM
    demfer
    demfer New Member
    Why do it yourself? When they replace your engine for free you will get a free transmission fluid change!
    SC4333 and Norfolk757 like this.
  12. Jul 27, 2024 at 5:44 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Would they have to drain the tranny fluid when they replace the engine?
  13. Jul 27, 2024 at 5:57 AM
    ocman40
    ocman40 New Member
    Was thinking the same thing, guess we will get a free trans fluid plus coolant flush lol
  14. Jul 27, 2024 at 7:00 AM
    demfer
    demfer New Member
    This is the way
  15. Oct 21, 2024 at 11:51 AM
    Dozer466
    Dozer466 New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    Those of you that are switching to a different fluid (Amsoil, Redline, Castrol etc.), how long are you waiting between drain and fills? Would it be ok to wait a week between each drain and fill? I'm assuming this wouldn't be an issue even though some of the fluid is synthetic.
  16. Oct 21, 2024 at 12:25 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’m no where changing the WS yet. A week between drain and fills is fine.
