Transmission Fluid Question
Discussion in '1st Gen Tundras (2000-2006)' started by FlightSimGuy, Dec 18, 2022.
  1. Dec 18, 2022 at 1:40 PM
    FlightSimGuy
    FlightSimGuy [OP] New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    So, to start out with I feel like an idiot and am embarrassed to tell anyone this, but I done messed up. So I changed my oil, which I've done several times just fine, but was distracted while doing so (perks of running a small business) and accidentally drained the wrong pan. Then proceeded to overfill my engine oil. I then drove about 20 miles before realizing what I did after the transmission wasn't shifting right. Hey, I said I feel like an idiot, get past it.
    So, my question is, can I refill the AT fluid with the same amount I drained and then drive it to the local dealer for a full flush and filter change? It's about 45 miles to the dealer. It's the sealed transmission and is about due for a flush, so I'd rather they do it.
    Thanks!
  2. Dec 18, 2022 at 1:57 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    Don't forget to drain the extra from the engine!
    Don't feel too bad. You aren't the first and definitely won't be the last! (I'm doing an oil change next week. )
    FlightSimGuy[OP] likes this.
  3. Dec 18, 2022 at 2:02 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm not sure why a transmission flush would be needed. Fill it up to the correct amount following the recommend process and you should be good assuming no damage was done which is probably unlikely.
  4. Dec 18, 2022 at 2:03 PM
    FlightSimGuy
    I'm doing a full oil change today to do that and get rid of the old oil. With no distractions.
    Can I steal your Village Idiot tag?
  5. Dec 18, 2022 at 2:04 PM
    Notarobot
    2013 CM
    It's earned, not stolen.
    SD Surfer, shifty` and Jack McCarthy like this.
  6. Dec 18, 2022 at 2:04 PM
    FlightSimGuy
    I thought about doing this but wasn't sure if it would be OK.
  7. Dec 18, 2022 at 2:05 PM
    FlightSimGuy
    Gotcha. :rofl:
    Notarobot[QUOTED] likes this.
  8. Dec 18, 2022 at 2:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Put a Fumoto drain valve on the engine oil drain PRONTO so there's never again a bad case of mix-n-match.
  9. Dec 18, 2022 at 2:20 PM
    FlightSimGuy
    I've seen those! They look cool but I wasn't sure how good they are.
  10. Dec 18, 2022 at 2:22 PM
    Notarobot
    2013 CM
    Just don't install it on the transmission pan. :rofl:
    TTund16 and Jack McCarthy like this.
  11. Dec 18, 2022 at 2:22 PM
    FlightSimGuy
    Shut up. :rofl:
  12. Dec 18, 2022 at 2:26 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I too drained my transmission fluid on my first oil change back in 02 only because with the skid plate on, I thought the tranny pan was the bottom of the engine. So you’re not alone.
  13. Dec 19, 2022 at 7:35 AM
    FlightSimGuy
    Well, I refilled it with the same amount and it seems to be shifting okay. I may still do a flush if it has any more issues. Thanks for the advice, guys.
  14. Jan 3, 2023 at 10:11 PM
    FlightSimGuy
    One more question. I filled the ATF back up and redid the oil change right before I left on a two week trip. Someone mentioned that overfilling the oil may have caused some to overflow into the cylinders? I just got back today and am wondering if I should check anything before I start driving it again.
  15. Jan 3, 2023 at 10:23 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I doubt it would have gotten past the piston rings, but you could pull the sparkplugs and spin the engine with the starter. But if it ran with all the extra oil in it, and didnt grenade, i'd think its safe.
  16. Jan 4, 2023 at 6:27 AM
    FlightSimGuy
    OK. It is a Yota after all. :D
  17. Jan 4, 2023 at 7:01 AM
    Notarobot
    2013 CM
    I changed my oil yesterday. I must have looked at the transmission pan bolt a 100 times. :rofl:
  18. Jan 4, 2023 at 8:02 AM
    FlightSimGuy
    I bet. :rofl:
  19. Jan 4, 2023 at 3:45 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I blew out about 5 quarts of oil because I forgot to install the oil filter.
    Been there, Done that.
    Notarobot likes this.
