Transmission fluid level checking
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rotaryphoneuser, Nov 30, 2020.
  1. Nov 30, 2020 at 8:09 AM
    Rotaryphoneuser
    Rotaryphoneuser [OP] New Member
    Ontario. Canada
    2018 Cement CrewMax
    I have a 2018 and I did 3 drain and filled while engine was cold. I refilled it exactly same amount I drained. I'm planning to get a scangage 2 sometime later get accurate transmission temperature to top up or drain excessive fluid.
    My question is what need to be level. Truck or transmission pan?
    My truck is bone stock.
  2. Nov 30, 2020 at 8:14 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Truck level and transmission pan at 99°, pull level plug until flow is at a trickle. That will be the correct level.
    HulkSmurf14 and YardBird like this.
  3. Nov 30, 2020 at 9:30 AM
    Rotaryphoneuser
    Ontario. Canada
    2018 Cement CrewMax
  4. Nov 30, 2020 at 10:21 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Neither, truck needs to be on level ground with tires inflated correctly. How many times have you seen a level in a Toyota service center.
    Rocko9999 likes this.
  5. Nov 30, 2020 at 10:30 AM
    AZBoatHauler
    So.Arizona
    No levels, but lots of lifts. I imagine the vehicle is off the ground when they do this at a dealership... @Ruggybuggy can you confirm the correct procedure? I believe the transmission pan is parallel to the frame rails but haven't crawled underneath to confirm that.
  6. Nov 30, 2020 at 12:00 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Lifts are leveled when installed assuming the four post style.
    Jchetty likes this.
  7. Nov 30, 2020 at 12:22 PM
    Rotaryphoneuser
    Ontario. Canada
    2018 Cement CrewMax
    When I was under the truck. pan looked like it was tilted towards back slightly but can't be sure. I should have took the level checker to the pan. And it's pouring out now..lol.
  8. Nov 30, 2020 at 12:38 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Level truck and not the pan. Put a level on the frame rail in the center of the truck. Make sure its level side to side. Basically don't do it on your sloped driveway.
    When we put them on the lift the trucks sit fairly level on a two post. I used a drive on 4 post and when the hoist is on the locks its level to the ground.
    Bammer and AZBoatHauler like this.
  9. Jun 1, 2021 at 7:40 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    With factory SR5 suspension, when parked on level ground (as best I can measure), the truck is level side-to-side as measured on the frame cross member, but it is not level front-to-rear as measured on the side frame below the front door. On level ground, the truck rear sits a little high relative to the front, as the stock suspension appears to be. Does that sound right?
  10. Jun 1, 2021 at 8:16 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Here is the procedure.
    Ruggybuggy likes this.
  11. Jun 1, 2021 at 8:24 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Thanks, it says “maintain the vehicle in a horizontal position while adjusting the fluid level.” I’ve seen it recommended several times to park on flat ground, but the vehicle does not sit flat (front to rear) when parked on flat ground. I have an ability to do either with equal ease, just want to know what’s best.
  12. Jun 1, 2021 at 8:37 PM
    JeffMac
    Jeff
    South Florida
    Vehicle flat. The tranny pan is meant to have a slight angle to ensure proper fluid level.
    Ruggybuggy and SSPey[QUOTED] like this.
  13. Jun 2, 2021 at 5:53 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your over think it. Basically put the truck on level ground. I think I mislead by saying put a level on the frame of the truck. Just make sure the truck is on a level piece of ground front to back and side to side.
    SSPey[QUOTED] and JeffMac like this.
  14. Jun 2, 2021 at 6:22 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    when people lift and level their truck do they adjust the transmission fluid level............ just joking its not that exact
  15. Jun 2, 2021 at 9:07 AM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Less filling! Tastes great!
    Thanks guys, seems all will be ok.
    Ruggybuggy[QUOTED] likes this.
