Transmission Fluid Fill Plug
Discussion in '2nd Gen Tundras (2007-2013)' started by Thehigherthetruck, Jul 9, 2015.
  1. Jul 9, 2015 at 3:20 PM
    Thehigherthetruck
    Thehigherthetruck [OP] New Member
    2008 4x4 Toyota Tundra 4.7L V8
    Long story short, I drained my transmission fluid instead of my engine oil during, what I thought, was a routine oil change. Shortly after realizing I had drained the wrong pan (my engine oil levels didn't drop like they were supposed to, and I noticed the "oil" I drained was cherry red and smelled rather appealing, much like autozone) I corrected the problem and changed my oil regularly. The engine oil has since been changed and all of that is peachy. My only issue? Putting the tranny fluid I drained, back into the truck. I have been browsing forum after forum and I have learned that there is no fluid dipstick for the transmission and that it cannot be filled that way because the transmission is sealed. So, it occurred to me that I had to fill it with a pump from the underneath. That would be fine, if I could locate the fill plug. Every DIY instructional video is either for a Tacoma, a 5.7L 2010 Tundra, or an earlier model with a tranny dip stick (or any combination of unhelpful models and years). It seems no one owns a 2008 4.7L V8 Tundra. I really just want to get the truck moving again, so if someone could tell me how to locate the fill plug and what tools I would need, it would be greatly appreciated. Thanks much. -Josh
  2. Jul 9, 2015 at 5:13 PM
    Mike Tread lightly.
    south carolina
    1. Get under the truck.
    2. Look at the transmission where you drained it now.
    3. Look on the passenger(if my memory is right) side. You will see a plug about 3/4 the way up. You will need a allan key to open the plug. I want to say its 3/4 inch or 14 mm allan key you need to open it up.
    4. Replace the oil with fresh oil not from the pan... oil in the pan is now contaminated. Fluid should be just to the fill hole.
    5. Tighten everything back up drive for 5 to 10 miles confirm no leaks. Job done.
    Bob likes this.
  3. Jul 9, 2015 at 5:56 PM
    Thehigherthetruck
    Thank you for your advice, I'll give it a go tomorrow and repost to give you an update on my progress. I hadn't checked the passenger side at all because I was told it was drivers. Kind of dark out right now. Thank you much.
  4. Jul 9, 2015 at 7:48 PM
    Ouch....
  5. Jul 10, 2015 at 12:38 PM
    Mike Tread lightly.
    south carolina
    I dont think its on the drivers side. I might be wrong.
