Transmission fluid drain and fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by retho78, Mar 13, 2025.
  1. Mar 13, 2025 at 10:11 AM
    retho78
    retho78 [OP] New Member
    2015 Toyota Tundra Limited
    I am looking to do a transmission drain and fill on my 2015 5.7L with 185K miles. Should I go with Toyota WS, Aisin WS or Idemitsu WS fluid? Anybody have experience with Aisin or Idemitsu?
    Also, per the carfax service history, it was flushed at 73K miles.
  2. Mar 13, 2025 at 10:22 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Why not just use the Toyota? It's probably the cheapest and most readily available
    dundunDUN likes this.
  3. Mar 13, 2025 at 10:26 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Recently fully flushed mine at 60K. Got the Toyota WS from Amazon. 12 quarts.
    HulkSmurf14 and retho78[OP] like this.
  4. Mar 13, 2025 at 10:26 AM
    retho78
    Amazon has Toyota WS 6qt pack for $90 and Idemitsu 5qt is $45. I should probably check with my local dealership.
    bmw345 likes this.
  5. Mar 13, 2025 at 11:29 AM
    blenton
    blenton New Member
    RockAuto usually has good pricing on Aisin WS - around $7 a quart if memory serves, plus some reasonable shipping. I usually buy it by the 12 pack since shipping isn't any more than a four quarts. I have used Toyota and Aisin WS with very good results. The dealer went from $9 a quart to $19 so Aisin has been my go-to for the last few years.
    retho78[OP] likes this.
  6. Mar 13, 2025 at 11:33 AM
    retho78
    Yes, I saw it on rockauto and trying to decide which one to go with.
  7. Mar 13, 2025 at 11:34 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Using the current 25% off sale and free shipping over $75, you can get 8 qts of WS delivered for ~$82 from Serra/Toyota of Decatur. And you can be sure it's genuine Toyota. If you order from Amazon, be sure that the seller is an actual dealer or you could end up with fake parts, although I haven't heard of knock-off WS.
    WILLINH, HulkSmurf14 and retho78[OP] like this.
  8. Mar 13, 2025 at 11:35 AM
    retho78
    Thanks!
  9. Mar 13, 2025 at 12:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I've used both. Idemitsu has a comparable viscosity to Toyota WS. AISIN has a thicker viscosity and both idemitsu and Aisin wasn't brown colored like Toyota WS. I use Idemitsu in my Highlander. All 3 fit the bill...
  10. Mar 13, 2025 at 12:37 PM
    retho78
    Thanks.
