Transmission fluid drain and fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by FLTundra21, Jan 7, 2024.
  1. Jan 7, 2024 at 10:02 PM
    FLTundra21
    FLTundra21 [OP] New Member
    2021 Tundra SR5 crew cab
    I have a 21 Tundra SR5 and just hit 55k miles and want to do a drain and fill of my transmission fluid. I am not going to drop the pan. How many quarts of Toyota ATF WS will I need. Any suggestions/tips? Thanks in advance!
    sgtfluffy16 and Bobbyd like this.
  2. Jan 7, 2024 at 10:07 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    I'm preparing to do mine in the next week too for the first time. I've read that 4 quarts is generally enough, but a few people have needed 5-6 qts. I have 6 on hand for when I find the time to do the job myself.
    RustyShackle323 and Bobbyd like this.
  3. Jan 8, 2024 at 3:45 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Welcome to the forum!
    Recommend you search this topic. It is the magnifying glass at the top right of the page.
    You're on the right path regarding fluid type and your decision not to drop the pan. Advice above abut having 6 qts on hand per drain/fill is solid. Other recommendation is to always crack the fill plug first, then the level check, then the drain just enough so you know they aren't seized. Finally, scan tool to monitor temps, or practice the pin method.
    Good luck
  4. Jan 8, 2024 at 4:03 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Just did mine two weeks ago and drained right at about 5qts. I’d have 6qts on hand just in case. Mine sat in the garage for over a week before I did it and I lifted the front of the truck a bit as well. Some folks report seeing around 3.75qts.
    FLTundra21[OP] and Reddawg1100 like this.
  5. Jan 8, 2024 at 4:26 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Odd. I didn't know about the varying amounts of fluid people are reporting.
    I myself have never gotten more than four quarts out of mine. On ramps, I get 110 ounces, or 3.4 quarts.
    I drain the fluid into this graduated pitcher. It provides a very accurate measurement.
    https://www.amazon.com/gp/product/B08PDS3PB2?ie=UTF8&th=1
  6. Jan 8, 2024 at 4:36 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Anyone use the ScanGauge 3 to monitor tranny pan temps when doing the r&r on the tranny fluid?
    RustyShackle323 likes this.
  7. Jan 8, 2024 at 5:10 AM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    I’m coming from the Tacoma world so still learning tundras but Toyota sucked at filling the trans on tacos. A lot of them were underfilled from the factory (mine was a quart low when I bought it brand new in 2015). It caused a lot of shifting issues. Nothing serious but you could feel the torque converter engaging more than you should be able to. Sucked in stop and go heavy traffic because it would rev up a bit and then engage. After putting in the proper level, all shifting “issues” (if you can even call them issues) disappeared.
  8. Jan 8, 2024 at 6:18 AM
    RustyShackle323
    Stewart
    NC
    Yep, that is what I did.
    Xcumminsguy[QUOTED] likes this.
  9. Jan 8, 2024 at 6:52 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I'm assuming the varying amounts drained has to do with how long you let the truck sit before draining. 4 qt seems average. I'll probably let mine sit 4 or 5 days. I'm almost to 30k so I'm coming up soon for first drain and fill.
  10. Jan 8, 2024 at 6:56 AM
    wauto
    wauto New Member
    mike
    Your suppose to do this with transmission up to temp.
  11. Jan 8, 2024 at 7:08 AM
    MadMaxCanon
    the level check yes, but the drain you dont have to.
  12. Jan 8, 2024 at 9:19 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I heard about that. Fortunately my 2014 had the proper amount. On the Tundra I just replace what I drain. Works fine for me.
    rmorse[QUOTED] likes this.
  13. Jan 8, 2024 at 9:23 AM
    AZBoatHauler
    So.Arizona
    Nope
    Gene_in_FL likes this.
  14. Jan 8, 2024 at 9:30 AM
    Xcumminsguy
    NY
    Check level at something like 100-111* F iirc.
  15. Jan 8, 2024 at 11:52 AM
    RustyShackle323
    Stewart
    NC
    Official temp is 99-111F.
  16. Jan 8, 2024 at 12:32 PM
    Okiebug
    Okiebug New Member
    I'd go ahead and just do a total fluid exchange; you don't need to drop the pan to do it. I've completed it twice and it's not that difficult and it's nice to have the peace of mind that all the fluid is brand new. Probably not for everyone but here is the link the video I followed to do it. You'll need 15 qts, and I have used Valvoline Maxlife Synthetic both times with absolutely no issues at all. Its a fraction of the price of the Toyota WS/
    (2) Toyota Tundra Comprehensive Transmission Oil Change - YouTube
  17. Aug 12, 2025 at 12:24 PM
    sgtfluffy16
    sgtfluffy16 New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    I have a 2019 Tundra TRD Pro that I bought brand new. I bet half of its life for a little less than half is all been Towing around 7 to 8,000 lb. I'm at 6 years of ownership so it's time to do the transmission fluid drain and fill. I'm at 22,000 miles. And I'm going to drain the transmission pan and then fill it back up using Amsoil OE fuel efficient ATF. Back in 2020 and I'm sure that you can find my thread on this but I had a case open with Toyota corporate regarding the transmission fluid temperatures and the 2019 external transmission cooler being removed and replaced with a warming puck. Since then I bought the 2018 thermostat sandwich plate and install that and then ran the lines up to an external transmission cooler which I mounted at the front of my radiator. Never had a problem with fluid temperature since. And surprisingly only needed to add about half a quart of fluid when I did that. I plan to again drain my transmission fluid and install new and I will be pinning the thermostat open. I have four quarts and I hope that that is enough
  18. Aug 16, 2025 at 3:18 AM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
    Given you have a transmission cooler you can easily perform a full fluid exchange.
    https://www.youtube.com/watch?v=cB8MdGgwg68
