Transmission fluid drain and fill question
Discussion in '3rd Gen Tundras (2022+)' started by 24LTD, Aug 15, 2025.
  1. Aug 15, 2025 at 9:56 AM
    24LTD
    24LTD [OP] New Member
    Going to do a drain and fill soon. My question - is temp check mode necessary or can I just use my scan tool and wait until the transmission pan sensor reads 95-100 degrees and pop the check plug? Is temp check mode some mystical thing that's doing something else in the background or is it just simply telling me when the temp is ready? Thank you!
  2. Aug 15, 2025 at 10:18 AM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    Yes it's important to run the engine to get up to the proper range before releasing excess fluid via the drain. (That's why I'll measure how much comes about and add about 1/4th quart more when refilling.)
    An alternate method to determine the transmission temperature is to use an electronic digital laser temperature gun and aim it up at the top of the transmission while running to get the temp. (I compared this with my digital scanner it was very accurate...so will just use the temp gun for next service.)
    Also make sure you have the truck level to get the correct amount drained out.
    24LTD[OP] likes this.
  3. Aug 16, 2025 at 8:00 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Scan tool is fine, it is the most accurate. It is what i use. I run it till it reaches 95F then open the overflow plug. Easy :thumbsup:
    Sisu87TRDOR and 24LTD[OP] like this.
