Transmission fluid D&F at 120K
Discussion in '2.5 Gen Tundras (2014-2021)' started by sea_weathered, Aug 4, 2025.
  1. Aug 4, 2025 at 8:35 PM
    sea_weathered
    sea_weathered [OP] New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Okay, I'm not sure what to do here. My 2018 Tundra has 120k on the ticker, I'm finding a consistent drumbeat of people on the internet saying that you should perform a transmission drain and fill every 60k. I'm all for keeping up on maintenance on my beloved truck, but somehow I cruised right on by that target milage and didn't perform that service. So, what now? Some say it's too late, that I will cause issues if I start now, and that I should just leave it and pray it lasts the lifetime of the vehicle. I do lug around an OVRLND camper 100% of the time, and I'm rolling on 37" tires, but I drive it very gently. Should I leave it, or start doing drain and fills now? How many of you have high milage and have never touched the trans?
    Pics for attention
    23Tundy, The Dude and KNABORES like this.
  2. Aug 4, 2025 at 8:56 PM
    blenton
    blenton New Member
    The idea that you should leave it alone is malarkey. The fluid will only continue to degrade and become more contaminated with wear material, furthering wear on the transmission - the valve body in particular.
    I am a firm believer in performing drain and fills as regular maintenance; it allows you to replace a portion of the existing fluid with clean fluid. The detergents and additives in the new fluid will helps to gently clean parts over time and replenish the depleted additives of the old fluid.
    A flush, on the other hand, can occasionally cause issues, but it’s usually from the flushing method that dislodges debris that finds its way in to the valve body and mess up a transmission. This is where the old adage of leaving it alone comes from, and is grossly over exaggerated.
    In your case, I would perform a drain and fill with every oil change (assuming you change oil every 5k) over the next 20k miles. That will replenish the fluid to something like 80% new; the math is easy I’m just too lazy to work it out right now. Sorry :/ But suffice to say, you would have clean, fresh fluid without compromising the integrity of the transmission. The d&f procedure is quite simple - if a little particular in some respects - and quite doable by most anybody that can change their own motor oil. Lots of write ups on the site here.
    My ‘13 is at 230k miles of hauling and towing with some hard use bordering on abuse in there. At 180k miles I sent a sample of transmission fluid to Blackstone labs for analysis, in preparation for installing a supercharger. The oil properties were very healthy, but it was a little dirty from wear material and such. They recommended basically what I recommended to you above. Before that, I performed a D&F every 30k miles since new.
    23Tundy, MEGA VOL, 2mchfun and 5 others like this.
  3. Aug 4, 2025 at 9:04 PM
    sea_weathered
    Pacific Ocean
    The service does look pretty straightforward, I’m kicking myself for buying into the idea that it was a lifetime fluid. I’m just concerned now that I’ll do more harm than good considering the mileage that I’m at.
    blenton[QUOTED] likes this.
  4. Aug 4, 2025 at 9:21 PM
    blenton
    blenton New Member
    Meh, don’t feel bad about it. You’re not the only one.
    You would do more damage by not changing it, IMO. We purchased our sequoia used and I changed the transmission fluid around 100k miles. It was dark and stinky, but not quite burned. That was a year ago, and the transmission only got better with each D&F. Coming up on the third change soon.
    2mchfun and WILLINH like this.
  5. Aug 4, 2025 at 10:00 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    The don’t change it if it’s old comes from old fluid being flushed (not drained and filled) and when you’re pumping close to 3-5 gallons through a transmission that has never been serviced, it causes problems
    when doing just a drain and fill that negates most of that because you’re just replacing what’s in the pan, no flushing or dislodging anything; yes do the d&f but know that if you’re having problems now it potentially could make them worse (depending on the actual issue)
    the actual service interval that I’ve read from a Toyota master tech is 60k D&F with normal use (daily driver) but 30k if towing; so I’d split the difference for heavy off roading
  6. Aug 4, 2025 at 10:04 PM
    joseph_womack
    Joe
    Louisiana
    Oh and I originally thought it was bs that Toyota transmissions really do work better with Toyota WS, but it’s not, do yourself a favor and D&F with legit Toyota WS and not Valvoline Maxlife or something else
    on paper the Valvoline is a better fluid, but the Toyota transmissions just like WS so much more
    MEGA VOL, 2mchfun, WILLINH and 2 others like this.
  7. Aug 4, 2025 at 10:07 PM
    sea_weathered
    Pacific Ocean
    Are most of you going through the process of bringing the trans up to proper temperature and opening the fill straw plug? Or simply replacing the fluid taken out with the same quantity by measuring it?
  8. Aug 4, 2025 at 10:09 PM
    joseph_womack
    Joe
    Louisiana
    do it the proper way by getting it to temp and using the check plug; make sure you pin the thermostat (if you have a transmission cooler)
  9. Aug 4, 2025 at 10:15 PM
    sea_weathered
    Pacific Ocean
    I guess it’s time to drop a few bucks on a scanner tool
    joseph_womack[QUOTED] likes this.
  10. Aug 4, 2025 at 10:17 PM
    joseph_womack
    Joe
    Louisiana
    the carista one that most people use in here is cheap and is just bluetooth to your phone, it does require a subscription after a free trial I think, but is always handy to have
  11. Aug 4, 2025 at 10:18 PM
    joseph_womack
    Joe
    Louisiana
    Technically you dont need a scanner, you can put the tundra into atf check mode and it will warm up the fluid and turn off a light on the dash to tell you when its the right temp, I can link you the procedure if you give me your year make and model
    23Tundy and 300BLK like this.
  12. Aug 4, 2025 at 10:26 PM
    sea_weathered
    Pacific Ocean
    Awesome! 2018 5.7L DC 4x4 TRD SR5, I’m not sure what other make/model specs there are?
  13. Aug 4, 2025 at 10:26 PM
    joseph_womack
    Joe
    Louisiana
    really just 4.6L vs 5.7L, but sometimes the temp numbers differ per years
  14. Aug 4, 2025 at 10:29 PM
    joseph_womack
    Joe
    Louisiana
    There ya go, thats the ALLDATA procedure to check the fluid level on your truck, it tells the temperature if you were going to read off the scanner and it also tells you how to put the truck in atf check mode
    If it were me I would double check that you understand/can get the truck in the check mode before you actually drain the pan
    It calls for 3.2 Qts if youre doing a drain and fill
    sea_weathered[OP] likes this.
  15. Aug 4, 2025 at 10:33 PM
    sea_weathered
    Pacific Ocean
    This is killer! Thank you man!
  16. Aug 4, 2025 at 10:33 PM
    joseph_womack
    Joe
    Louisiana
    No problem! Hope it all works out for ya
  17. Aug 4, 2025 at 10:38 PM
    blenton
    blenton New Member
    Like @joseph_womack said, I’d recommend ATF WS from either Toyota or Aisin (the transmission is made by Aisin). Idemintsu is also a good choice. Several guys use the Valavoline stuff but I’m not a fan of multi-vehicle ATF and others have seen shuddering and issues when switching.
    Also, even a cheap scan tool and the Torque App on your phone will get you ATF temps for less than $30. I use my head unit that is tied to the OBDII port via iDatalink Maestro. You could even use an IR thermometer on the pan to get you in the ballpark; it’s just needs to be in a temperature range.
    The fluid check procedure is simple. I usually refill with 4 quarts then open the check plug when it’s warm (not hot) and wait for a strong trickle.
    joseph_womack likes this.
  18. Aug 4, 2025 at 10:50 PM
    sea_weathered
    Pacific Ocean
    I plan to just grab four quarts or the Toyota WS from the local dealer, and I need a scan tool anyway. This one looks like it has a live data feed https://www.amazon.com/dp/B07N66TTQG
  19. Aug 4, 2025 at 11:00 PM
    joseph_womack
    Joe
    Louisiana
    what scanners can read toyota trans temps can be a bit finicky, not all of them can even with the live data feed
  20. Aug 4, 2025 at 11:10 PM
    sea_weathered
    Pacific Ocean
    Okay, not as straightforward as I was hoping. That Carista unit looks solid, I just hate subscriptions.
  21. Aug 4, 2025 at 11:13 PM
    blenton
    blenton New Member
    It can be hit or miss with the readers, but most are pretty good. Saying that and it took Banks until earlier this year to get their super hoopty iDash to read transmission temps :eek:
    But I’d suspect that one you have listed can read it.
  22. Aug 4, 2025 at 11:21 PM
    joseph_womack
    Joe
    Louisiana
    I work at a shop and we have supplied scan tools, but I wanted to buy one for myself, so I got a TopDon AD500 but its like $170
    They sell this one below for $39 but its got a coupon for $29, it has live data; and from what I remember the tundra trans temps are under engine live data because its an ECT, so it might show it
    I can check tomorrow on where the temps are located but if this topdon works out its a pretty good deal for just engine codes and live data- Launch is also a good budget, linked below is their's too
    https://www.amazon.com/Scanner-Read...tive,118&sr=1-25#averageCustomerReviewsAnchor
    https://www.amazon.com/LAUNCH-CR529...ix=launch+toyota+scanne,automotive,120&sr=1-9
    sea_weathered[OP] and blenton like this.
  23. Aug 4, 2025 at 11:51 PM
    sea_weathered
    Pacific Ocean
    Thank you!
  24. Aug 5, 2025 at 2:19 AM
    Retired...finally
    You might consider adding $40 to the D&F budget and have a skosh of the old ATF sent off to Blackstone labs for a professional opinion of it's condition. Tell them what you've told us and they will give you guidance to decide a future D&F plan.
  25. Aug 5, 2025 at 3:07 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    why is it necessary to pin the thermostat. I just added a transmission this weekend and followed all the steps to get it to temperature and pull the overflow plug until the fluid slows……but I didn’t have the thermostat pinned. Is that something i should go back and do?
  26. Aug 5, 2025 at 3:54 AM
    ljburns
    ljburns New Member
    I changed my fluid at about 120K miles. I did it via the transmission cooler line so I could replace it all at once without a flush. I didn't have any issues and that was 50k miles ago.
    sea_weathered[OP] and Tunrod like this.
  27. Aug 5, 2025 at 5:28 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Pat, MEGA VOL and Mdnitedrftr like this.
  28. Aug 5, 2025 at 5:54 AM
    shawn474
    MoCo, Maryland
    Ok so I guess I know what I am doing this week / weekend…..need to repeat the process and pin the thermostat. Hopefully driving it until i am able to do that isn’t damaging anything :confused:
    BrandonL812[QUOTED] likes this.
  29. Aug 5, 2025 at 8:25 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    That car care nut video posted is an older one. In one of his newer tranny videos, he said his shop will not touch your fluid if it has over 100k on it. Not even a drain and fill. With that being said, if it was my truck at 120K, I’d still do a drain and fill. A little at a time is far safer than all the fluid at once.
    MEGA VOL and joseph_womack like this.
  30. Aug 5, 2025 at 8:38 AM
    joseph_womack
    Joe
    Louisiana
    You’re most likely fine, likely hood there was a massive air bubble in the cooler causing you to be low when you checked the level is impractical; but it’s still cheap insurance to double check it and is easy enough
