Transmission fluid change
Discussion in '2nd Gen Tundras (2007-2013)' started by gbing, May 18, 2016.
  1. May 18, 2016 at 8:03 PM
    gbing
    gbing [OP] New Member
    I'm wanting to change transmission fluid on a 2013 Tundra 5.7 4X4. Does anyone have any instructions for this. I plan to drain the pan, then fill transmission back and remove the cooler return line, start the truck and drain fluid then refill a few times until I get most old fluid out. My question is getting the truck into transmission temperature monitoring mode to check the level of fluid. I have seen that people have posted that you can jump between terminals 4 and 13 on the OBD2 and get the truck into transmission temp monitoring mode where the "D" light will come on after temperature reaches desired temp to check level. Has anyone done this and will it work on the 2013 year model? Dealer wanted to do a power flush for $299, however I contacted Toyota and the person I talked to said they don't advise doing a flush under any circumstances, only do a drain and fill. Thanks
  2. May 18, 2016 at 8:10 PM
    So if they recommend a drain and fill why do something else?
    Oh, and welcome!
  3. May 19, 2016 at 3:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This has been discussed before on here with @LOTSOFTOYS and we came to the conclusion, i think, that you should just drain and flush.
    I have no idea about the mods to be able to see temp and fill level. Sorry.
  4. May 20, 2016 at 4:28 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  5. May 20, 2016 at 7:09 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Drain and fill ftw. Let the professionals do it
    Wilbur, ColoradoTJ and T-Rex266 like this.
  6. May 20, 2016 at 7:47 PM
    Per the maintenance manual:
    30k miles: check level, trans sensors and function. Toyota did this for me free of charge.
    60k miles: same as 30k unless you fall under special operating conditions. Then it is time for a drain and fill.
    This was 7 qts and cost me 199.00 out the door for this service
    90k miles: same as 30k service
    120k miles: same as 60k mile service.
    Never flush a transmission, that is for toilets. Service transmissions. I have a friend in TX that has his own shop for 30+ years and has told me about some of these flushing machines. That was just scary. He also told me to drain the pan once a year, new filter, add fluid and you will be good to go.
    Now with our trucks and not having a dip stick to check level, I would just go off what Toyota recommends. This also happens to help with warranty work in the slim chance the transmission fails. There have been people denied warranty work due to missing the 30/60/90k transmission checks. To be honest, it should be denied if one neglects the vehicle.
    Rica25 and JTP like this.
  7. May 20, 2016 at 8:23 PM
    X1000
  8. May 21, 2016 at 6:54 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Pretty much everyone who owns a truck falls under the 60k interval. Especially here in co. Mtn driving, towing etc... 60k drain and fill and call it good
    T-Rex266 and ColoradoTJ like this.
  9. May 21, 2016 at 8:53 AM
    I'm glad you think so (and I agree with you). My dealership closest to me says not to do anything to the transmission until 120K miles. I actually had to fight with them about doing the 60K drain and fill. I will do it again at 90K. Not sure I will use the Toyota dealership though.
    Rica25 likes this.
  10. Jun 14, 2017 at 6:49 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    1) drive down to the local Speedy Oil shop
    2) Write check
    3) There is no step 3
  11. Jun 15, 2017 at 4:02 AM
    Marco
    Marco New Member
    Do it yourself, do it right,
    Don't trust some jiffy lube flunky
  12. Jul 2, 2017 at 5:14 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    I talked to Toyota while I was in for getting my gears swapped. 60k is the mileage on doing the trans fluid CHANGE. They said absolutely DO NOT FLUSH. Drain it and filler back up. Pretty simple.
    Rocko9999 likes this.
  13. Aug 20, 2017 at 8:00 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Next on the to do list then fluids are all "did".
    Am a bit skeptic and lost in that forums discussion how to change. Is it that way for a 2nd gen, 08, 5.7??
    Rica25 likes this.
  14. Sep 3, 2017 at 7:46 AM
    Les7311
    Ok folks need opinion
    Do I need 13 quarts of WS to complete the transmission change??
  15. Sep 3, 2017 at 8:06 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My notes say that the capacity is 12.3 quarts, so, I'd say ya.
    Rica25 likes this.
  16. Sep 3, 2017 at 8:21 AM
    Les7311
    Nysssssss, and thank you!!!
    eBay list at $9.80/ quart and I plan to do surgery this week
  17. Sep 3, 2017 at 9:22 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You might want to try your local dealer first - my dealer sells WS for $7.25/Litre Canadian $$ - much cheaper than Ebay or Amazon.
    Rica25 likes this.
  18. Sep 3, 2017 at 11:14 AM
    Les7311
    I did here. Parts quoted me almost $12 a quart. eBay will be my bestie again.
    Rica25 likes this.
  19. Sep 3, 2017 at 11:15 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Wow. Maybe I'd better jump on that price before they decide they made a mistake.
  20. Sep 3, 2017 at 11:52 AM
    Les7311
    $;?%{!#{^!63!),!
    Who the hell decides to overtighten the overflow plug on the trans-pan?
    Am doing a pre-pull on the bolts, and the hex is on the verge of snapping with no sign of loosening....
    Fffffgggfffaaaaggggg!!!!
    Hilandr and Rica25 like this.
  21. Sep 3, 2017 at 11:53 AM
    Les7311
    eBay always less I noticed.....
    Rica25 likes this.
  22. Sep 3, 2017 at 12:07 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Give it a sharp rap dead on with a small-ish hammer, and try again.
  23. Sep 3, 2017 at 12:21 PM
    Les7311
    Nope. Plan B.
    Will have to drill out b
    Splines stripped on plug. Darnittttt!!!
  24. Sep 3, 2017 at 5:46 PM
    Les7311
    Alas!!!! I got it loose
    Sprayed plug with liquid wrench
    Drove about 13 miles to get pan warmed
    Applied vice-grips and
    BANG!!!!!! Off she came.
    I will have to order a new plug....
    Surgery next week
    Rica25 and Wynnded like this.
  25. Sep 3, 2017 at 7:51 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Glad you're winning, even if a bit delayed. :thumbsup:
    I have to work up the ambition to do this myself one of these days very soon, I'm going all out with a DIY "flush" and replacing the strainer too.
    Rica25 and Les7311 like this.
  26. Sep 3, 2017 at 7:56 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Me too. I have to work up the ambition in sync with a day off. I have all the parts and fluid sitting together on the tool shelf. Sigh....
    Rica25 likes this.
  27. Sep 3, 2017 at 8:09 PM
    Les7311
    Well I guess one hour with an extra pair of hands and you good. Am riding eBay juice tomorrow
  28. Sep 3, 2017 at 8:13 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I know when I'm all done, I'm gonna look back and wonder why I procrastinated for as long as I have. I'm hoping and planning for next weekend.
    Rica25 and Wynnded[QUOTED] like this.
  29. Sep 6, 2017 at 2:17 PM
    Les7311
    eBay has 12qts WS for $113 free shipping.
    If you search around eBay and making two orders, you could get it for a little over $100.....
  30. Sep 6, 2017 at 2:33 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Valvoline max life full syn trans fluid meets all Toyota ws requirements says right on the bottle and cost's much less. That's what I use since I get it free at my shop
    Sparkzilla likes this.
