Transmission fluid change on my Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Jake92, Aug 3, 2019.
  1. Aug 3, 2019 at 4:39 PM
    Jake92
    Jake92 [OP] New Member
    2000 Toyota Tundra SR5 4x4 TRD
    im very happy to see what I did today. The pan was a pain to get off but when I did I was happy. The previous owner did the bare minimum at maintaining this truck. It’s at 346,923 miles and I’m changing the transmission fluid and the filter. I’m happy with what I see in the am and how good the fluid was when I drained it. I was honestly dreading this. I feel a lot better about this truck now that I see what I see.
    MS22, SouthPaw, bmf4069 and 1 other person like this.
  2. Aug 3, 2019 at 4:52 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Looks like he was at least changing transmission fluid!
    Jake92[OP] likes this.
  3. Aug 3, 2019 at 4:57 PM
    Jake92
    @Filthyphil I used to drive this for the previous owner for weekend work, and a few years back I put 2 quarts in it it because it started slipping and was low. Stopped slipping after that so that’s why the fluid might be clean hahaha
    Filthyphil likes this.
  4. Aug 3, 2019 at 6:07 PM
    Filthyphil
    Phil
    Gotcha why was it low?
  5. Nov 14, 2019 at 12:49 PM
    Professional Hand Model
    Hand Protectors
    I have a theory that it was short 2 quarts because the factory manual says a drain and fill is 2 quarts. We know (today) the drain and fill is about total 4 quarts +/- per a Toyota correction and real world evidence today.
    Maybe someone followed the wrong instruction?
    Also, probs reason for many of the A340f earlier years transmission failures. Bad manual info.
  6. Nov 14, 2019 at 1:00 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Crazy how many miles that trans has lasted!
    When I serviced mine, I drained it into a container and put the same about back in. Probably do it again in another month or so and when it hits 200K, I will do the filter.
  7. Nov 14, 2019 at 1:01 PM
    SouthPaw
    2000 Limited 4x4 AC
    When I did my drain and fill, I think only two quarts came out.
  8. Nov 14, 2019 at 1:06 PM
    Hand Protectors
    When I did mine (for the first time last year after others being in charge) 3.5 quarts came out.
    Did some mediation after running down multiple internet rabbit holes on the A340f and decided to add another 3/4 quart for experimentation. Was fairly smooth before (no problems) and with the added fluid it shifted smoother. I check the fluid with my engine running at hot. I make sure the dipstick is just a hair over the H line.
    SouthPaw[QUOTED] likes this.
  9. Nov 14, 2019 at 1:13 PM
    Hand Protectors
    Looks like minimal shavings on the magnets, too. Confirms for me to just leave this transmission alone other than frequent fluid drain/fill changes. I think Marbles pulled his pan and confirmed minimal shavings on his 2002, as well. One less work thing that needs checking.
    marbleville likes this.
  10. Nov 14, 2019 at 1:18 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What I find most impressive about these trucks is that a lot of them hit 350K miles even though they have been neglected.That's amazing when you think about it.
    FrenchToasty and Filthyphil like this.
  11. Nov 14, 2019 at 1:23 PM
    Hand Protectors
    Yep. I was watching a youtubes on this guy about Land Cruisers. He had all the different generations lined up. IIRC, he was discussing the 4.7L engine which is the one the earlier 1st Gen Tundra shares and he said Toy made these engines to last 25 years in the third world. Maybe the A340f transmission, too?
  12. Nov 14, 2019 at 1:33 PM
    SouthPaw
    2000 Limited 4x4 AC
    You aren't kidding! The ones around here are completely hammered and still selling for $5K+! What is strange, is most of them are 2WD though which is surprising for Colorado. I am still shocked what I paid for mine.
    What is the proper method of checking the trans fluid? Hot in gear/neutral?
    MS22 likes this.
  13. Nov 14, 2019 at 1:36 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was told operating temp in neutral. That's what I do.
  14. Nov 14, 2019 at 2:50 PM
    Hand Protectors
    Someone double check this older service procedure bulletin. I grabbed it from a link on A340f research but cannot determine if the checking fluid in PARK at full operating temp is the correct method. The DEXII is a giveaway on the pages age.
    @Festerw
  15. Nov 14, 2019 at 2:50 PM
    Hand Protectors
  16. Nov 14, 2019 at 2:51 PM
    Hand Protectors
    For those A340f transmissions.
  17. Nov 14, 2019 at 3:10 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I know that the 00-03 FSM that I refer to(can't find 2004 FSM) uses that same method. Mine don't have pretty pictures like yours :)
  18. Nov 14, 2019 at 3:19 PM
    Hand Protectors
  19. Nov 14, 2019 at 3:23 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Service manual I have shows the same procedure but lists ATF Type IV.
  20. Nov 14, 2019 at 3:55 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Just curious, what reasons would cause it to be necessary for me to change my Tran fluid as the Owners Manual states ?
    from 2004 OM....
    "Change automatic transmission fluid only
    as necessary
  21. Nov 14, 2019 at 4:08 PM
    Hand Protectors
    Its arbitrary by design. I believe my manual says if dark or burnt smelling to change. Also, the recco miles were around 50k (half that for severe driving).
    Fortunately, over the years I had the shops (at great expense) change all my fluids early and often. I think this earlier change interval is even more important the older the vehicle becomes.
    Wished I had just done it myself early on due to the ease and low cost.
    hammeron and BubbaW[QUOTED] like this.
  22. Nov 14, 2019 at 4:17 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The way I look at it, it's a fluid. All fluids like this break down eventually. Spending $20-30 on ATF is a small price for peace of mind. Unfortunately, changing the fluid in the double cabs is more difficult but still doable.
    Festerw and BubbaW[QUOTED] like this.
  23. Nov 14, 2019 at 4:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    That's what I am finding out from reading here and other articles. At my cough cough age and other physical limitations(vertigo sucks), I'm having to let others do some of this initial maintenance that I have neglected over the years but learnt my lesson recently on here and won't mention what I paid the dealer for parts/labor :D
    Did pick up parts for valve cover gasket changeout as soon as this artic wx subsides !
  24. Nov 14, 2019 at 4:31 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not on the 04 DCs they've still got a drain plug and dipstick.
    It's an easy 20-30 minute job for piece of mind.
    bmf4069, speedtre and BubbaW[QUOTED] like this.
  25. Nov 14, 2019 at 4:32 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah I just realized he had an 04. That's the odd ball year that still has the 4 speed right?
  26. Nov 14, 2019 at 4:33 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Correct, the 04 DC is like a bastard step child.
    FirstGenVol[QUOTED] likes this.
  27. Nov 14, 2019 at 4:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s funny with the newer tranny(forget the number) they use WS fluid and claim it’s a lifetime fluid....pssshh
    And it’s not terribly difficult to do a full fluid swap under the power of the trannys own pump. I did a full 12qt swap on our 4Runner at 80k and I’m really glad I did, used amsoil ws equivalent.
  28. Nov 14, 2019 at 4:39 PM
    Hand Protectors
    Everyone ripped you for that receipt paid which I though was mostly within reason. A couple parts they gouged and the labor was slightly higher due to stealer status.
    Overall, it was a thorough job and I doubt you’ll be reporting back like many coming through here do here with post-partem problem$$$ caused by el cheapo shade tree (or by their own accord).
    BubbaW[QUOTED] and FrenchToasty like this.
  29. Nov 14, 2019 at 5:08 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks, now I got a new name for Matilda :)
  30. Nov 14, 2019 at 6:52 PM
    SouthPaw
    2000 Limited 4x4 AC
    I checked mine tonight and I was about 1.5 quarts low. I had one extra and it brought it just shy of the sweet spot line. I’ll put half in tomorrow but it seems to be shifting better already.
