Transmission Fluid 1st Gen Tundra 2 Wheel Drive
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Feb 20, 2020.
  1. Feb 20, 2020 at 4:35 AM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I am interested in hearing from owners who have never serviced the transmission in their Tundras. I recently bought my 2006 double cab 4.7. The transmission has never been serviced and now has 161k miles on it. It is working smoothly with no known problems. I had the local Toyota dealer service dept go over the truck and they did not recommend any service to the transmission. The owners manual does not recommend service. The Tundra has never been driven in the way it would meet the special conditions requiring service. I will put only 3 or 4k on the Tundra yearly mostly in town miles. I had tranny failure in a 2003 Park Avenue within days of changing the fluid, so I am hesitant to service the Tundra tranny. i have read all the past posts and understand lots support the drain and fill. My next oil change at Toyota I will ask to have the fluid level checked and let me see the color/smell of the fluid. If the fluid is black/smells burned, the do a drain and fill. The miles I drive I will have around 200k miles on it 10 years from now. I was told by the long time transmission shop owner who replaced the transmission in my Park Avenue to " never change the fluid in a high mileage vehicle because the new clean fluid can dissolve sludge and failing seals/gaskets."
  2. Feb 20, 2020 at 7:30 AM
    Professional Hand Model
    Hand Protectors
    Your manual does not suggest transmission fluid service/change? Are you sure?
    FrenchToasty likes this.
  3. Feb 20, 2020 at 7:46 AM
    Tundrius
    Tundrius New Member
    Jonah
    08 tundra, matching 10 prius!
    I made the mistake of changing the fluid on my 95 land cruiser at 225k. Took 3 bottles of conditioner before it started shifting smooth again. At the same time if I had your truck at 160k I would service it.
  4. Feb 20, 2020 at 8:08 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    yea, at this point I would leave it alone.....
    most people just drain and refill every 30K or so...
    but if yours is a SEALED system. (there's no drain plug or stick to check it)
    let it roll
    revtune likes this.
  5. Feb 20, 2020 at 8:46 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I'm a drain and fill proponent ( I did it on my 06 at 86K and will do it every 30K miles)...but based on your specific situation and the fact that it's a "sealed system", if it's working fine, I'd leave it alone. There are plenty of these trucks out there with 200K+ miles with the original trans. fluid.
    BubbaW likes this.
  6. Feb 20, 2020 at 10:25 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Personally I'd do a drain and fill. I do not beleive it will hurt anything. Then in 3,000 miles I would do it again.
    Here's my annual posting of this video.
    https://youtu.be/o690DovjDAc
  7. Feb 20, 2020 at 10:31 AM
    KissMyAxe1
    KissMyAxe1 New Member
    Utah
    2008 Black Tundra SR5 Crewmax
    Mine's in the shop right now getting new tranny and differential fluid. I have no records of it ever being changed out, so hopefully it doesn't cause problems. Mine's also a 2nd gen with 250k miles..
    1rooster likes this.
  8. Feb 20, 2020 at 10:51 AM
    Hand Protectors
    Might I axe what your manual states about fluid changes?
  9. Feb 20, 2020 at 11:06 AM
    KissMyAxe1
    Utah
    "Change automatic transmission fluid only as necessary.
    Generally, it is necessary to change automatic transmission fluid only if your vehicle is driven under one of the Special Operating Conditions listed in your “Scheduled Maintenance Guide” or “Owner’s Manual Supplement”. When changing the automatic transmission fluid, use only “Toyota Genuine ATF WS” (ATF JWS3324 or NWS9638) to aid in assuring optimum transmission performance.
    Notice: Using automatic transmission fluid other than “Toyota Genuine ATF WS” may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimate- ly damage the automatic transmission of your vehicle.
    Please contact your Toyota dealer for further details."
  10. Feb 20, 2020 at 11:08 AM
    Hand Protectors
    What, specifically, are these ‘Special Operating Conditions’?
  11. Feb 20, 2020 at 11:19 AM
    KissMyAxe1
    Utah
    The Scheduled Maintenance Guide suggests replacing tranny fluid every 60k miles if you're towing primarily, and to replace differential fluid every 25k miles if you're also towing primarily. If you're not towing, it suggests an inspection and to replace if needed. Transfer case oil is the same as the transmission.
  12. Feb 20, 2020 at 11:20 AM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    I got 4 quarts of the Toyota WS stuff on Amazon and did a drain and fill on my 2006 with 130,000. I don’t have great service records from the previous owner but the stuff I took out was almost exactly the same color as the stuff I put in. I still plan on doing the 4 quart drain and fill every 30k miles.
    Bulldog_tundra likes this.
  13. Feb 20, 2020 at 11:23 AM
    KissMyAxe1
    Utah
    My truck was bought in 2008 with like 150 something miles, and then in 2009, there was a service record indicating the truck had over 60k miles. there's another record in 2010 showing 80k something miles, and then after that, I just see registration records every year. So I'm sure it's due for a change. I didn't notice the time intervals noted for tranny and differential fluids..
  14. Feb 20, 2020 at 12:14 PM
    tundrainsc
    06 Limited 4.7 2WD
    To state more accurately. The owners manual only gives recommendations up to 120k miles. It says to inspect the fluid. See other posts in this thread for exact language.
  15. Feb 20, 2020 at 12:19 PM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    I think the important thing is NEVER do a TRANSMISSION FLUSH!!!!
    drain and refill
    ONLY USE TOYOYA FLUID FOR THE TRANNY... yea its $7 each... but in the long run... you will be glad
    I got 218,000 miles on my 2002 sequoia before selling it.... tranny was strong and shifted just fine...
  16. Feb 20, 2020 at 12:20 PM
    KissMyAxe1
    Utah
    Why not a flush?
  17. Feb 20, 2020 at 12:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Confucius say "watch video @FirstGenVol posted in this thread."
    Bulldog_tundra and Whothefat like this.
  18. Feb 20, 2020 at 12:24 PM
    KissMyAxe1
    Utah
    lol I'll watch it later. The oddities of work... They're super particular on youtube videos, but pretty much nothing else unless blocked by the network policy.
  19. Feb 20, 2020 at 12:28 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Leave it. 255/265k on my 05 loaded all the time and towing. No issues. I did add a little when I developed rear seal leak due to center carrier bearing failure after 200k.
    revtune likes this.
  20. Feb 25, 2020 at 7:21 AM
    antnat96
    antnat96 New Member
    Anthony
    Charlotte, NC
    Beige 2001 Tundra Access Cab SR5 2WD
    I've got 150k on my 2001 Access Cab V8 2WD and never replaced. Maryland State Police (first owner) did who knows what with it, previous owner towed a small lawncare trailer regularly, I've only pulled a big hay bale trailer around the barn a few times.
    No transmission issues or hard shifting.
