Transmission feels like it's slipping
Discussion in '2.5 Gen Tundras (2014-2021)' started by dan0229, May 12, 2015.
  1. May 12, 2015 at 9:32 AM
    dan0229
    dan0229 [OP] New Member
    Lawrenceville GA
    2015 black TRD 4x4
    Have a 2015 TRD 4X4 that, when turning to the left at a slow speed, the tranny feels like it's slipping for a few seconds. My 2002 Tacoma did the same thing. Anyone else feel this?
  2. May 12, 2015 at 9:49 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Nope. Take it to the dealer.
  3. May 12, 2015 at 10:20 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hmm, are you sure its not the wheel loosing traction or the Trailer Sway Control kicking in?
    Trailer Sway Control helps the driver to by selectively applying brake pressure for individual wheels and reducing engine torque when trailer sway is detected. Trailer doesnt' need to be attached, just a feature of the truck.
  4. May 12, 2015 at 11:53 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    It's funny you should say that about your tranny slipping. I have a 2015 dbl cab SR5. Only 1000 miles on it. N The other day when I made a turn, but was giving gas I felt that mine too was slipping. I thought it was just me, since I could not make it happen again
  5. May 12, 2015 at 12:09 PM
    csuviper
    Broomfield, CO
    I thought i felt this a few times since i got my truck as well (2012) ... only when turning. i think it has something to do with limited slip or other features.
  6. May 12, 2015 at 12:19 PM
    I would take it to the dealer and take them for a test drive to show them what you mean. If it is normal (caused by something else) then at least its documented you addressed it if something else comes up.
  7. May 12, 2015 at 12:51 PM
    csuviper
    Broomfield, CO
    I agree with Sean. On a new truck if you think something is acting up then take it in. If it was only once then you can probably afford to wait to see if it happens again, then take it in.
  8. May 12, 2015 at 1:21 PM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    I've been experiencing the same thing with my 2013 since day one. Every time I leave the stop sign at the end of my street, it feels like that if I give it too much gas. It threw me at first, but I don't believe it's actually slipping. I think it's just the throttle revving before the tranny has a chance to catch up. I haven't bothered to check, but I'm pretty sure our throttle is fly-by-wire rather than direct connection from the pedal.
  9. May 12, 2015 at 1:46 PM
    csuviper
    Broomfield, CO
    Fly by wire is correct
  10. May 12, 2015 at 2:46 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've always felt that it was the transmission had down shifted to a lower gear than I've been used to in other, lesser geared vehicles; allowing the engine to rev a bit more, then upshifting making it feel like it suddenly "catches".
  11. May 12, 2015 at 3:07 PM
    Mike Tread lightly.
    south carolina
    Sounds like the transmission computer is trying to hunt on you. The computer cant see what your next move might be turning left or right. Unless the traction control is seeing something? Im going to assume no lights are on the dash indicating a problem.
    All that said like sean and csviper take it to the dealer see if the tech can reproduce the problem or the tech can check computer in the transmission like fuild temps and presssures to see if a problem is internal.
    Im going to sound retarded here but have you check for any leaks under the truck and wet? Reason I say we have one post of a looks to be a bad seal on there transmission of course Toyota is taken care of it.
  12. May 12, 2015 at 5:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Like I mentioned, my truck does this; the 07 Sienna we just picked up does this; my work vehicle, a 2014 Blue Bird with an Allison transmission, does this. Is it possible that this is the software programming and that some of us simply aren't accustomed to slushboxes with more that 3 or 4 ratios?
    To a degree, it "feels" to me that the transmission's ECU base programming is downshifting in anticipation of a more aggressive throttle application after braking for the corner putting the engine at a little higher RPM (by maybe only a few hundred revs) so it pulls better, rather than lugging from closer to just above idle.
    ...of course, I could just be overthinking it. :)
  13. May 13, 2015 at 5:44 PM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    I left a stop sign today at lunch (turning left). It was a bigger intersection, with more driving straight before the turning left. I heard and felt my rear end/transmission banging. At first I thought it was my lunch box sliding against my tailgate. Then I realized my lunch box was in the back seat.
    tat2ude39 likes this.
  14. May 13, 2015 at 7:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What'd ya have for lunch?
    tat2ude39 and T-Rex266 like this.
  15. May 13, 2015 at 8:44 PM
    irishpride114
    Travis
    A little pastrami. Nothing special. Lol.
    tat2ude39 and Wynnded like this.
  16. May 14, 2015 at 4:46 AM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I've noticed this same thing on my new Tundra. I've also felt it on several other new vehicles (different manuf). I think it exactly what Wynnded mentioned - it's the programming of new transmissions. I am only speculating, but I bet they are programmed with that delay in order to improve MPG - slower engagement, no mega launches from stop lights, etc.
    Honestly, it's quite annoying to me. Do any of the programmers/interceptors alter the shift points to improve this?
  17. May 14, 2015 at 5:58 AM
    Check out this link.............http://tunertools.com/toyota-truck-...-t-for-tundra,-sequoia,-tacoma-&-4runner.html
