Transmission drain bolt stripped….
Discussion in '3rd Gen Tundras (2022+)' started by bignoah, Mar 15, 2025.
  1. Mar 15, 2025 at 6:33 PM
    bignoah
    bignoah [OP] New Member
    Was doing a drain and fill on the transmission and slightly stripped the drain plug.. I think I can get it back off to replace. Does anyone know if there is a Lexus bolt part similar to the front diff that I can use to replace the hex?
    also, I could’nt seem to get the leveling straw out, maybe I’m using the wrong size hex?
  2. Mar 16, 2025 at 5:13 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Drill and Tap for new bolt imo, or you'll be worrying about leaking for the rest of its life.
  3. Mar 16, 2025 at 5:21 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Or remove pan and weld in new nut or just replace pan
  4. Mar 16, 2025 at 5:40 AM
    A new pan with gasket is 159.00.
    I believe Banks has an aftermarket one as well.
    Tundrastruck91 likes this.
  5. Mar 16, 2025 at 9:29 AM
    firehawk003
    firehawk003 New Member
    Sounds like he may have stripped the hex, not the actual threads going into the pan.
  6. Mar 16, 2025 at 12:54 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    People can't read.
    Mr Badwrench likes this.
  7. Mar 16, 2025 at 12:54 PM
    bignoah
    Yes this is correct, stripped the hex.
    Wondering if there is a bolt I can replace it with so I don’t strip it again
  8. Mar 16, 2025 at 1:36 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Take that one out with vise grips and head down to your nearest ACE or True Value Harware store. They have drawers full of all sorts of bolts. They have a thread tester so you can get the correct size/pitch. Use a torque wrench putting it back in. Only about 20 ft lbs. with a new crush washer.
  9. Mar 16, 2025 at 2:05 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    30ft lbs with new washer according to the fsm.
    I'm questioning if the OP was using the correct size hex where the plug stripped and he can't get the filler tube out.
    Correct hex is 6mm for both.
    eddiefromcali and Superdave1.0 like this.
  10. Mar 16, 2025 at 2:07 PM
    Superdave1.0
    Superdave1.0 New Member
    Dave
    LX470, 2025 Civic Si
    Just have to use a quality hex socket and keep it straight. Also make sure you are in all the way. Hex heads can last forever, just have to be cautious with them and of course torque to spec with a new crush washer.
    In other words I vote new oem bolt, keep the hex.
    BlackNBlu and Retroboy1989 like this.
  11. Mar 16, 2025 at 2:22 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Always correct hex bit: https://www.amazon.com/dp/B07MDLCLML
    Always correct torx bit: https://www.amazon.com/dp/B000YOVIIU I use it for damaged hex holes as well, that are not longer accept a standard hex bit. Torx+ is slightly larger, security torx is slightly smaller, which gives some variety to pick from.
    Most of Toyota bolts are subpar. Mild steel, strip easily.
  12. Mar 16, 2025 at 2:54 PM
    Retroboy1989
    Northern Utah
    I have lexivon torque wrenches. I have been happy with them. I just got some flip sockets for lug nuts
    Are the hex tools good quality?
  13. Mar 16, 2025 at 3:24 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Okay. OTC torx bits are better (harder). Still, Lexivon is more sturdy than most of HF, HD or Lowes bits.
  14. Mar 16, 2025 at 4:26 PM
    bignoah
    Thanks for the advice! I’m was using this set from HF:
    Might ask the dealership to replace the hex and check the fluid level, since I’m not sure I checked at the right temp
  15. Mar 16, 2025 at 5:02 PM
    Superdave1.0
    Dave
    If you weren't 100% sure of the fluid temp, then definitely have the dealer or a reputable shop check your fluid level. If it's still under warranty you might want to consider not going to the dealer. They will document that you did a drain and fill yourself and screwed up the head of the bolt.
    bignoah[QUOTED][OP] likes this.
  16. Mar 16, 2025 at 6:04 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    +/- 0.5 qt it won't even notice.
    Nm6300'asl likes this.
  17. Mar 16, 2025 at 6:16 PM
    bignoah
    So far it’s been running fine, changed it yesterday. I assume I would notice if something’s wrong by now? Driven about 60-80 miles
  18. Mar 16, 2025 at 6:29 PM
    Superdave1.0
    Dave
    How do you know it's only that amount? And why would Toyota and all manufacturers specify a temperature range if it "won't even notice."
  19. Mar 16, 2025 at 7:32 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You are right, it can tolerate much more. I actually tested that, on another, older transmission made by Aisin :) Full fill, including torque converter, is 8.2 (IIRC) qt. It started noticing something with 1.5 qt less in sump, and the first signs of foaming with more than 1 qt overfilled. Nothing too bad, just first signs.
    Because that's the zero point.
  20. Mar 17, 2025 at 7:43 AM
    dJunior
    dJunior New Member
    CT
    is there a guide anywhere for drain and fill for trans and relearning?
  21. Mar 17, 2025 at 7:50 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    One thing I noticed when I did my drain and fill recently....the hex bit went into the drain bolt but not all the way...I wiggled it a bit and it went in a bit deeper. If OPs hex didn't fit the straw, I'd guess that the bit is not that well made and off in shape or size a bit. Would explain why it stripped the bolt and wouldn't fit in the straw.
  22. Mar 17, 2025 at 11:04 AM
    bignoah
    Maybe my hex bit was too short? Does it need to be longer to reach the straw?
  23. Mar 17, 2025 at 11:09 AM
    eddiefromcali
    Eddie
    100% Stock
    yes, the straw is deep in there.
  24. Mar 17, 2025 at 12:05 PM
    lapoolboy
    lapoolboy New Member
    Heh heh .... that's what she said!
    VCheng likes this.
  25. Mar 17, 2025 at 12:12 PM
    eddiefromcali
    Eddie
    100% Stock
    dont want no short hex man
    kirkb and Superdave1.0 like this.
  26. Mar 19, 2025 at 7:13 AM
    bignoah
    Asked the dealership if they could check the fluid level for me but would be $250..
    Going to check it myself this weekend, any suggestions on how to get it to the right temp to check? Should I drive it then let it cool down or let it warm up then check? Also should I pin open the thermostat?
  27. Mar 19, 2025 at 7:29 AM
    Superdave1.0
    Dave
    Need a scanner that can read transmission temps. Then look up the proper range spec from Toyota.
  28. Mar 19, 2025 at 7:38 AM
    eddiefromcali
    Eddie
    100% Stock
    Follow this process to ensure youre within temp range
    https://www.youtube.com/watch?v=ij51acD69Zc
    Superdave1.0 likes this.
  29. Mar 19, 2025 at 8:57 AM
    Retroboy1989
    Northern Utah
    This guy's torque specs are wrong. His are 2nd gen torque specs.
    30 ft lbs for both drain and fill.
  30. Mar 19, 2025 at 12:16 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I dropped mine off the night before for my dealer appt for transmission fluid change. Start from a cold transmission otherwise I don't think you'll get to proper fluid temp
