Transmission drain and fill
Discussion in '3rd Gen Tundras (2022+)' started by 124-329 Solo, Aug 25, 2024.
  1. Aug 25, 2024 at 5:22 AM
    124-329 Solo
    124-329 Solo [OP] New Member
    2012 Tundra DC
    ARE Z Series Solar Auxillary battery lights etc
    Has anyone done this yet that would like to share? Is it the same process as the last gen? Will the paper clip in the OBD work the same?
  2. Aug 25, 2024 at 3:06 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The 2/2.5 gen is simple drain, fill and shift through gears.
    3rd gen has couple extra steps after drain, fill and shift through gear. Air bleed oil pump and reset ATF thermal degradation estimate.
    sudobash likes this.
  3. Aug 25, 2024 at 3:48 PM
    wrxlover
    wrxlover New Member
    dakota
    2022 sr5
    for what its worth i did a drain and fill on my third gen just measured what came out put back the same amount,was about 20000 miles ago all i do with my truck is tow everythings been great ymmv but drain and fill seems to be fine to me
    Tundrastruck91 likes this.
  4. Aug 25, 2024 at 4:39 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Do it cold - drain the pan, measure what comes out and put that exact amount of OEM back in. Repeat once each week after for 3 weeks. All good for another 30K if you tow or 60k if not.
    24LTD, ARB1977 and BDATundra like this.
  5. Aug 25, 2024 at 5:36 PM
    124-329 Solo
    2012 Tundra DC
    Thanks, makes sense to me if both fluids are the same temp the drain and fill with same amount can't go wrong.
    303Gen3 likes this.
  6. Aug 25, 2024 at 5:40 PM
    BDATundra
    BDATundra New Member
    Bob
    2024 1794 Edition 4x4 (non-hybrid)
    None - yet...
    Subscribed
  7. Aug 27, 2024 at 4:18 PM
    iforceAZ
    iforceAZ New Member
    So how does one "air bleed oil pump" and "reset ATF thermal degradation estimate"
  8. Aug 27, 2024 at 4:21 PM
    AZBoatHauler
    So.Arizona
    The resetting the thermal degradation counter isn’t new and it’s done through TechStream. It’s only supposed to be done when you change more than half the fluid.
    sudobash and FrenchToasty like this.
  9. Aug 27, 2024 at 5:49 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Using Techstream.
    AIR BLEED OIL PUMP WITH MOTOR ASSEMBLY
    NOTICE:
    Bleed the oil pump with motor assembly after replacing the automatic transmission assembly or replacing the automatic transmission fluid.
    (a) Connect the GTS to the DLC3.
    (b) Turn the ignition switch to ON.
    HINT:
    Do not start the engine.
    (c) Turn the GTS on.
    (d) Enter the following menus: Powertrain / Stop and Start / Active Test / Oil Pump.
    Powertrain > Stop and Start > Active Test
    TESTER DISPLAY
    Oil Pump
    (e) Perform the " Oil Pump" Active Test for 10 seconds or more.
    ATF THERMAL DEGRADATION ESTIMATE RESET
    NOTICE:
    If either of the following conditions is met, perform ATF Thermal Degradation Estimate Reset.
    • The ATF has been replaced.
      HINT:
      If 50000 or more is displayed for the Data List item "ATF Thermal Degradation Estimate", thermal degradation of the ATF is suspected. Perform ATF Thermal Degradation Estimate Reset after replacing the ATF.
    • Approximately 50% or more of the ATF has been replaced during a repair of the transmission or a similar operation.
    NOTICE:
    (d) Enter the following menus: Powertrain / Transmission / Utility / ATF Thermal Degradation Estimate Reset.
    Powertrain > Transmission > Utility
    TESTER DISPLAY
    Kap1 and eddiefromcali like this.
  10. Aug 27, 2024 at 6:07 PM
    303Gen3
    Golden Colorado
    I'd just not worry about it since I knew the fluids were fresh, or pay the Stealership to do something I would not trust them to do.
  11. Sep 6, 2024 at 6:35 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    How many quarts for drain and fill - need to make sure have enough on hand.
    303Gen3[QUOTED] and Team_Toyota like this.
  12. Sep 9, 2024 at 6:12 PM
    303Gen3
    Golden Colorado
    I'd say to be safe have 5 qts on hand. It won't go bad so if you buy extra it will keep until you do the next drain and fill a few weeks later. I will have to look in the book and see what it says the capacity is - usually have one more quart on hand than what the book says it needs for total - ie 12 quarts capacity at 3 drain and fill would be 4 quarts per drain and fill IF 4 quarts is the measured amount per drain. Thus have an extra quart on hand.
