Transmission drain and fill-Toyota Fluid or Maxlife?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Mar 10, 2022.
  1. Mar 10, 2022 at 9:14 AM
    Rocko9999
    Rocko9999 [OP] New Member
    What is everyone using for their transmission fluid when doing drain and fill?
  2. Mar 10, 2022 at 9:20 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You will get multiple answers to this. I would say use the Toyota WS fluid and dont think about it lol.
    WILLINH and Rocko9999[OP] like this.
  3. Mar 10, 2022 at 9:20 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    OEM fluid. I will use different brands at times for diffs, xfercase, etc but with a transmission I dont like mixing and would stick to OEM. I also never do a flush, drain and fill only.
  4. Mar 10, 2022 at 10:26 AM
    Rocko9999
    Thanks. For ambient temp drain and fill do I need to mess with the cooler thermostat or anything else? Just drain and put back same amount of new fluid?
  5. Mar 10, 2022 at 10:37 AM
    frichco228
    some do the typical drain, measure the fluid drained and fill same amount, ambient temp/cool fluid. Personally this is what I have done on any of my vehicles vs the more formal process.
    Or there is the more formal process if getting up to temp-
    There’s a very specific procedure to ensure your tranny is at the right temperature. It involves pinning your OBD and shifting in a specific sequence, then quickly filling until the fluid is dripping out. I think there’s some youtube videos..
    https://www.tundratalk.net/threads/5-7-tundra-diy-transmission-fluid-change.106946/
    I'm sure others will chime in on their preferences. And there are past threads here about this if you want to try a search
    Rocko9999[QUOTED][OP] likes this.
  6. Mar 10, 2022 at 10:43 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I've used Maxlife on all my toyotas.
    never an issue.
    Zebruaj, omgboost and Rocko9999[OP] like this.
  7. Mar 10, 2022 at 10:47 AM
    Rocko9999
    Thanks, appreciate the info. I saw the formal process and it looked overwhelming.
  8. Mar 10, 2022 at 10:53 AM
    poop_bubbles
    poop_bubbles New Member
    The best thing to do is follow the service manual which I’m fairly certain does not call for ever draining or filling with anything. It’s lifetime fluid.
    Partial change is a waste of time and money.
    A full change is difficult to do at home, costs a lot at the dealer, and while better than a partial change, is also a waste of time and money.
  9. Mar 10, 2022 at 11:28 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Manual says to replace at 60k
    Rocko9999[OP] and nobodyintexas like this.
  10. Mar 10, 2022 at 11:31 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ...and drain & fill is as easy as changing your oil.
    WILLINH likes this.
  11. Mar 10, 2022 at 11:38 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive used both. Can’t tell a difference
  12. Mar 10, 2022 at 12:01 PM
    timsp8
    NY
  13. Mar 10, 2022 at 12:57 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I did not know if the transmission was ever serviced but when I did drain and refill, I used Maxlife. *knock on wood* has been trouble free so far, put about 30k miles on since then.
    Rocko9999[OP] likes this.
  14. Mar 10, 2022 at 1:02 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If WS fluid is better than maxlife…..fresh maxlife is better than 90k mile WS.
    drain, measure, refill. Dont over think it
  15. Mar 10, 2022 at 1:22 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    They say it’s a lifetime fluid, it is not. Under extreme conditions it should be changed, my driving habits aren’t extreme, but the climate im in is. I do full fluid swaps using the transmissions internal pump using amsoil fluid
  16. Mar 10, 2022 at 1:23 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    My trans fluid exchanges were always at a dealership with Toyota fluid. I did about about 3 or maybe 4 in 110k and 13 years and it still shifted exactly like brand new with not a single stumble that I ever remembered when I traded it last week.
    Firm when I needed it to be firm and smooth when conditions called for it to be smooth.
  17. Mar 10, 2022 at 1:49 PM
    Rocko9999
    What did they charger each time?
  18. Mar 10, 2022 at 2:59 PM
    eharri3
    eharri3 New Member
    maybe in the 160s. With anything other than oil the way new cars are so fluid type and procedure sensitive I was always paranoid independent shops would muck it up.
  19. Mar 10, 2022 at 3:04 PM
    poop_bubbles
    For $160 you weren't getting a full fluid change. But, imagine what you could have instead, with inflation, had you not wasted that money.
    230k miles here, never drained or changed until 200k and the transmission has shifted like new the whole time.
    Would I change it again at 200k? Sure. Every 30k? Complete f'n waste of time money and energy.
    I'm starting to do motor oil every 10k instead of 5k. Comes out super clean there too.
    Ely010606 likes this.
  20. Mar 10, 2022 at 3:08 PM
    poop_bubbles
    It's a lifetime fluid.
    Please, show us a case where it was proven the transmission failed due to not changing the fluid.
  21. Mar 10, 2022 at 3:09 PM
    poop_bubbles
    You guys are all free to waste your time and money on whatever you want, but please stop pretending it makes a difference.
  22. Mar 10, 2022 at 3:11 PM
    FrenchToasty
    Mo
    Bone stock
    If it’s a lifetime fluid, why did you change yours? Shits and giggles?
    I’m not spending your money, I don’t see the big concern.
    texasrho83 likes this.
  23. Mar 10, 2022 at 3:23 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    With a name like poop bubbles I'm not at all surprised when I read this guy's posts.
  24. Mar 10, 2022 at 3:24 PM
    poop_bubbles
    Literally for shits and giggles. Others can learn from my shits and my giggles too.
  25. Mar 10, 2022 at 3:24 PM
    MadMaxCanon
    watch the care care nut channel. Dudes a toyota master tech, he tells you why the lifetime fluid is bullshit. Also why 10k mile oil changes are bullshit.
    You should never beleive 1 word from anybody that has any ties to advertising or marketing. A toyota technician has 0 reason to lie to you. If anything, he has to do less work if you beleive the lifetime fluid BS, but alas, here he is telling you its BS for the good of the consumer.
    WILLINH, Oey12, WFD473 and 1 other person like this.
  26. Mar 10, 2022 at 3:27 PM
    FrenchToasty
    Mo
    Bone stock
  27. Mar 10, 2022 at 6:13 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    Owners manual doesn’t say anything about lifetime fluid. I drain and fill mine about every 20 to 30k miles with WS. Holds about 4 quarts. Takes longer to remove the skid plates than it does to drain and fill.
  28. Mar 10, 2022 at 6:26 PM
    eharri3
    eharri3 New Member
    My impression is the owner’s manual does not treat it like a lifetime fluid, only Toyota marketing does. They like to be able to advertise no maintenance items to their customers. The manual I think suggests an inspection at 100k under normal driving and a 60k full change under severe duty. You don’t recommend inspections of what you think you designed as a forever fluid.
    My other theory is based off the fact that no dealership I ever talked to wanted to do a full flush before 100k. They would tell you all day the fluid was lifetime so it didn’t need it, then suddenly become agreeable when you asked for a drain and fill. The wishy washy language in the manual about trans service and the lifetime fluid marketing is about giving dealers an excuse not to have to do the big bad scary full flush until after the warranty period. The fear being, with trucks that tow and haul and have wear and tear on the drivetrain a full flush before 5/60 might upset something and cause a warranty issue.
  29. Mar 11, 2022 at 3:25 AM
    Bammer
    Monroe, CT
    Please stop, you made your point, time to move on sir.:hattip:
    dbittle likes this.
  30. Mar 11, 2022 at 3:46 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    this sorta relates to this thread...
    last weekend my garage (detached) started to smell like a month old 5 gallon jug of hobo piss.
    well...my Transmission pump jar refiller thing was in the attic & the weather heated up enough to squeeze out whatever leftover trans fluid was in the tube.
    soaked the rafter & dripped.....juuuusst missing the wife's Telsa (yes, plaid). catastrophe averted. I must be livin' right.
