Transmission Cooler for 2017 Tundra w/Tow Package
Discussion in '2.5 Gen Tundras (2014-2021)' started by NY98M3, Jan 15, 2023.
  1. Jan 15, 2023 at 9:49 AM
    NY98M3
    NY98M3 [OP] New Member
    Looking to see if there is an upgrade for the 2017 Tundra transmission cooler. Im seeing that the transmission cooler is part of the AC condensor. Id like to have a more dedicated transmission cooler.
    Does anyone know if the make an upgraded transmission cooler for the 2017 Tundra?
  2. Jan 15, 2023 at 10:28 AM
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
    A bit of a lift, compressor, bags
    You can buy any cooler and install it but keep in mind that the thermostat decides whether to flow oil to the cooler. There should already be a thermostat installed from factory because of the model year of your truck. I installed a Setrab cooler and I really like it for when I’m towing. The finicky part of an install is perhaps making the bracketry. Depending on where you buy a cooler the brackets may be available for your truck specifically. I’d check into genuine cooling systems online.
  3. Jan 15, 2023 at 11:22 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Talk to @Genuine Cooling Systems
  4. Jan 15, 2023 at 12:17 PM
    NY98M3
    I was able to find this on their site. Looks like it still uses the factory cooler (through the AC condenser) but adds the Setrab cooler after it.
  5. Jan 15, 2023 at 3:27 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Yeah @Genuine Cooling Systems is who you want to talk to. I know he has everything listed as out of stock though because of Toyota parts but he might be able to sell you one of the kits that is just an add on cooler since theres no Toyota parts in it. He was super quick to respond when I bought my cooler from him.
    FISHN43, JCBerb and Saltyhero13 like this.
  6. Jan 21, 2023 at 8:54 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Yup, Genuine Cooling Systems 100%
    MadMaxCanon likes this.
  7. Jan 21, 2023 at 9:16 PM
    zeekevin
    zeekevin New Member
    I been wanting to convert to a standalone cooler also. I was thinking of using the parts from the 2007-2009 models. Also possibly rerouting the power steering cooler lines to run to the current trans cooler in the ac condenser
