Transfer case leak?
Discussion in 'General Tundra Discussion' started by Billy I, Feb 28, 2020.
  1. Feb 28, 2020 at 5:53 AM
    Billy I
    Billy I [OP] AKA Storm Shadow
    2013 Tundra TRD Off Road White
    I noticed this leak recently that I believe to be the transfer case? Does anyone have any input on this? Planning on taking to a local Toyota dealer to diagnose this weekend or early next week. Trying to go armed with any possible info. Thanks! (2nd Gen with ~80,000 miles) 20200223_163004.jpg 20200223_163023.jpg 20200223_163029.jpg
  2. Feb 28, 2020 at 7:05 AM
    coTony
    Tony
    Montrose, CO
    Before you go to the dealer do your due diligence and clean the entire area, not only where you can see at the bottom but way above and all over. I had a vehicle in the past (LandCruiser) with a LOT of miles and leaks everywhere. I spent a lot of time (almost entire weekend but it was most of the under hood area) but once clean and you drive for a bit then get it in the garage and shine a light you can see the shiny reflection and should be able to isolate the source of the leak. If you take the time to do this before the dealer visit you are arming yourself with facts before you get the bullshit from the stealership
    looking at your pics it appears it has been leaking for quite some time.
    15whtrd and TheBeast like this.
  3. Feb 28, 2020 at 7:05 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Well at least it's helping with the rust!
    But yeah its time to go get All the TC gaskets and new fluid, easy peasy....
  4. Feb 28, 2020 at 7:13 AM
    Billy I
    Thanks a lot for the suggestion. Will be able to get it cleaned good when the temps rise again here before taking it in next week.
  5. Feb 28, 2020 at 7:13 AM
    Billy I
    LOL. Helping with rust but not my driveway surface!
  6. Feb 28, 2020 at 7:25 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    1st and foremost check the fluid level. 2nd degrease. 3rd you can add a trace dye to the fluid and drive then hit it with a black light to id the leak, leak detection kits are a great tool to have in your garage and not that expensive.
    TheBeast and coTony like this.
  7. Feb 28, 2020 at 10:20 AM
    Billy I
    Thank you. Just had an oil change last weekend and all was well there. Great advice.
  8. Mar 9, 2020 at 6:40 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    From the top photo it looks like the front differential.
    15whtrd likes this.
  9. Mar 9, 2020 at 6:45 PM
    SuperWhite20
    Robert
    Georgetown TX
    Bolt is loose.
    BENWALES likes this.
