Transfer Case Front Driveshaft Seal
Discussion in '2nd Gen Tundras (2007-2013)' started by SnowB0und, Jun 30, 2024.
  1. Jun 30, 2024 at 3:11 PM
    SnowB0und
    SnowB0und [OP] New Member
    2013 SR5
    I went to change my transferase fluid and noticed my front output seal (to front drive shaft) is leaking. I did a few searches, but it's super difficult to find the right part on Toyota's new part website. Does anyone know what part number it is? Anyone done this before have any hints? I'd assume RTV on the splines, I just need to look up the torque spec for the output flange nut.
    I found this one (Toyota 90311-50039), but it doesn't specify if it's an input seal, rear drive shaft, or front.
  2. Jul 1, 2024 at 6:20 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    That is the correct seal for the front output. You will also need the nut 90179-24011 and O ring 90301-31003 to seal the splines, no sealant required.
    texasrho83 likes this.
  3. Jul 1, 2024 at 8:49 AM
    SnowB0und
    2013 SR5
    @Jowett Awesome, thanks! How did you find that? I was searching everywhere for the part numbers.
  4. Jul 1, 2024 at 9:00 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
  5. Jul 1, 2024 at 3:12 PM
    SnowB0und
    2013 SR5
    Thank you!
