trans
Discussion in 'General Tundra Discussion' started by spyro, Aug 18, 2021.
  1. Aug 18, 2021 at 6:21 PM
    spyro
    spyro [OP] New Member
    i have almost 100,00 miles, never had transmission fluid changed on a 12 tundra (sealed).
    dealer says they will flush, im confused, some say not to flush, on first change, but, one dealer dont touch the trans, and the other, only flush, any help? thnx
  2. Aug 19, 2021 at 5:25 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Drain and fill, repeat every couple thousand miles.
    Trooper2 likes this.
  3. Aug 19, 2021 at 7:47 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Don't have flushed. Toilets are flushed. Have or do a drain and fill. Roughly 3-4 quarts. As mentioned do again in a few thousand miles, maybe depending on how the fluid drain the 1st time looked. Important to measure and replace with same amount. :thumbsup:
    Bammer likes this.
  4. Aug 20, 2021 at 8:30 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    I went to my local dealer to learn what they did for their transmission service. It was some kind of power flush and they described a level check outside the factory service parameters. I walked away with no confidence and did it myself. Bought the various tools, the scan tool app to monitor pan temp, 24 qts Toyota WS fluid, and did a step by step service. Now it's right and I can do it whenever I want for the cost of fluid.
    Bammer, Trooper2 and AZBoatHauler like this.
