trans not engaging/slipping
Discussion in '2nd Gen Tundras (2007-2013)' started by weshaba, Jun 2, 2022.
  1. Jun 2, 2022 at 4:16 PM
    weshaba
    weshaba [OP] New Member
    wesley
    I have a 2009 4.7 v8 single cab and the transmission is giving me issues. If letting off the brake and quickly onto the gas, the rpms rev and then the transmissions grabs and the tires chirp. Would a drain and fill be advisable as an option or am I dealing with a bigger issue?
  2. Jun 2, 2022 at 4:51 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Yes... do that first, but Use the Amsoil transmission fluis with anti slip additive.
    snivilous likes this.
  3. Jun 2, 2022 at 6:06 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would do an entire flush, there's threads and videos on it. Disconnect the hoses off the trans cooler and put one in fresh fluid and put the outlet hose into a bucket. I had the same thing happened, and all new fluid didn't make any difference and ended up needing a whole new trans (but mine was pretty fucked and had been brutally overheated). You might get lucky and just need a torque converter, assuming new fluid doesn't fix it. I had a 4Runner where the converted went out and new fluid kept it limping for a few more months.
    weshaba[OP] likes this.
