Trans fluid change factory procedure
Discussion in '2nd Gen Tundras (2007-2013)' started by Ridesironhorse, Jan 16, 2024.
  1. Jan 16, 2024 at 9:48 PM
    Ridesironhorse
    Ridesironhorse [OP] New Member
    Brad
    South Alabama
    2013 4x4 Tundra
    Could someone please send me the Toyota trans fluid change procedure for my 2013 4x4
  2. Jan 17, 2024 at 12:32 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Lotsa proper videos.
  3. Jan 17, 2024 at 12:33 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
  4. Jan 17, 2024 at 3:53 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  5. Jan 17, 2024 at 9:35 AM
    Ridesironhorse
    Brad
    South Alabama
    2013 4x4 Tundra
    Thank you sir
  6. Jan 19, 2024 at 10:45 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    I am about to do my first drain and fill too.
    I kept getting conflicting temperature ranges for when to check the trans fluid. Each YouTube video or service recommendation had different temperature ranges for when to unplug the overflow port and when to plug the port and let the fluid cool before checking.
    I opened each of the attachments that Brums provided above.
    Here are the temperatures in Fahrenheit for each transmission type.
    TIS shows 5 different code transmissions for 2012:
    A750E - 97 - 115
    A760E - 127 - 138
    A760F - 127 - 138
    AB60E - 99 - 111
    AB60F - 99 - 111
    You can find the code for which transmission is in your truck of the inside of the driver's door. It is in the lower left corner of the sticker.
  7. Jan 19, 2024 at 2:42 PM
    Ridesironhorse
    Brad
    South Alabama
    2013 4x4 Tundra
