Trans capacity with oil cooler 04 tundra double cab SR5 TRD RWD V8
Discussion in '2nd Gen Tundras (2007-2013)' started by USERidiculousNAME, Apr 30, 2024.
  1. Apr 30, 2024 at 3:59 PM
    USERidiculousNAME
    USERidiculousNAME [OP] ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    How much transmission fluid does a 2004 Toyota tundra double cab SR5 TRD RWD V8 4.7L with tow package and separate external oil cooler hold? Draining all fluids from truck from every spot available
  2. Apr 30, 2024 at 4:17 PM
    Good luck. Should be in the FSM. Guess around 12.5qts or so.
  3. Apr 30, 2024 at 5:37 PM
    USERidiculousNAME
    Josh
    New Orleans
    Thanks I ordered 12 quarts but have a gut feeling I should get a couple more. Bought Valvoline trans oil but decided against it for Toyota T-IV
