tranny swap
Discussion in '1st Gen Tundras (2000-2006)' started by seaner, Sep 28, 2021.
  1. Sep 28, 2021 at 7:15 AM
    seaner
    seaner [OP] New Member
    sean
    will a 03 tranny fit in an 01 tundra?
  2. Sep 28, 2021 at 7:17 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I don't think they changed until 05. You could probably check if the part numbers are the same.
  3. Sep 28, 2021 at 12:26 PM
    If they are the same configuration ( both 4x4 etc.) then I believe they will.
  4. Sep 28, 2021 at 12:47 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    As long as it had the same engine, the transmission should work. If yours was a V6 and the transmission was from a V8 than the answer would be NO. 5speed vs. 4speed won't work with the ECU.
