Tranny problems on 2017
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by vetteguy, Jan 11, 2018.
  1. Jan 11, 2018 at 4:09 PM
    vetteguy
    vetteguy [OP] New Member
    2017 TRD double cab Blue
    canopy, running bars, custom tool storage
    Hello all,
    My name is Monte and i purchased a 2017 TRD SR5 back in August.
    Within a few weeks I started noticing some oddities about the shifting. The list is long, but here are a few of the most common issues I have...
    - every morning (engine cold) backing out of garage i get a delayed shift from Reverse to Drive. Pulling onto my street, tranny seems to be slipping from 1-2 and 2-3. RPMS will run up to 2300 or so while the tranny is only slightly grabbing and then slowly fully engage,(sometimes with a thud). If i hold a steady throttle while its slipping, it will start pulsing (lunging) almost like I'm goosing the throttle back and forth.
    - While driving, it occasionally will shift through all gears very quickly then downshift again. Almost like its confused. I'll get "hard" shifts mainly between 1-2, sometimes in other gears. Occasional hard downshifting as well.
    I have had in to the dealer twice now. They do seem to be trying to work with me on this, but they have not been successful in duplicating the issues on a steady basis to create a strong diagnosis in order to fix it. They recommend i continue to drive it until it gets worse, which it seems to be doing.
    Has anyone in the Tundra world experienced any of these issues?
    Thanks, Monte
  2. Jan 11, 2018 at 4:50 PM
    It takes the ECU time to learn your driving patterns.
    I always wait for the RPM’s to drop after initial start then go and drive easy until it’s at operating temps. All Toyota’s won’t shift as smoothly when it’s not warmed up. My Corolla does the same if I drive it hard when it’s not at operating temps.
    Also, welcome from CO.
  3. Jan 11, 2018 at 4:56 PM
    Welcome from Ohio! Sorry I can't answer on your tranny problems but maybe this guy would know.bruce-jenner-7.jpg
    Lol had to do it.
  4. Jan 11, 2018 at 4:57 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I have never experienced what you are describing in any of my cars.
    jeremyd likes this.
  5. Jan 11, 2018 at 4:58 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Has the fluid level been checked?
  6. Jan 11, 2018 at 5:03 PM
    vetteguy
    They checked fluid level the first time I brought it in.
    That was my initial though as well
    ColoradoTJ likes this.
  7. Jan 11, 2018 at 5:06 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Did you have to leave the truck with them for a while to cool enough to check the level? Assuming you don’t live within 2 blocks of the dealer.
  8. Jan 11, 2018 at 6:43 PM
    vetteguy
    Actually left with them for a couple days and explained to them how to mimic what I do when I drive it. They observed no issues. I then drove with their tech. It do some of the issues, but less apparent.
    They are getting more frequent and apparent as some time goes on. I'm thankful I got the extended warranty.
    Just wish I could enjoy my new truck more!!
  9. Jan 11, 2018 at 6:45 PM
    I’m sticking with my original post.
    darkknight2014 likes this.
  10. Jan 11, 2018 at 6:51 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Hes had the truck since august. Let it run till the vacuum drops off yes but no way you should have to wait until it hits warm temps for it to act normal. Something is wrong.
  11. Jan 11, 2018 at 6:52 PM
    Can you post video OP? Also, how many miles are on it?
  12. Jan 11, 2018 at 6:53 PM
    This is exactly what I was thinking.
    On my first 30k mile transmission inspection, they said the fluids needed topped off in the transmission, almost a qt.
  13. Jan 11, 2018 at 7:07 PM
    vetteguy
    I am a strong believer in letting a vehicle warm up a bit before taking off. It all starts every morning just shifting from R to D. I'll get as much as a 5 delay. Then when I am just pulling to the end of the driveway (30ft) I get a slight delayed shift at 5mph from 1st to 2nd gear.
    Anyway, I do appreciate any and all input. I do have a video I'll try to post that shows the tach and speed as it's slipping and "lunging".
    YsoSeRiouS! and T-Rex266 like this.
  14. Jan 11, 2018 at 7:12 PM
    Slayer
    Slayer Member
    Slayer
    take that video to dealer too... to see what they say
    report back bud
    landphil and ColoradoTJ like this.
  15. Jan 11, 2018 at 7:37 PM
    vetteguy
    Having trouble uploading the video.
    I did send it to my dealer service adviser the other day. He saw it and forwarded to their lead tech. Haven't heard back yet!
    I will keep you all posted!
    Thanks!!
  16. Jan 11, 2018 at 7:38 PM
    YouTube or another hosting site is best.
  17. Jan 11, 2018 at 7:38 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    OK, hopefully they actually did check your level with the proper procedure when they had it those days. These dipstick free transmissions are somewhat complex to check the level on, not hard, but there is a procedure that has to be followed closely. That said, they SHOULD be experts at it.
    Delayed shifting / higher shift points when cold is normal with mine, but even stone cold I don’t get a noticable delay in shifting from reverse to drive / drive to reverse, or any surging like you are experiencing.
    A video is a great idea, best of luck in getting this resolved quickly so you can enjoy your Tundra, rather than being frustrated by it.
    darkknight2014 and ColoradoTJ like this.
  18. Jan 11, 2018 at 7:43 PM
    vetteguy
    thanks!
  19. Jan 11, 2018 at 10:40 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Could’ve sworn this had to do with @ColoradoTJ Friday nights
  20. Jan 11, 2018 at 10:45 PM
    smslavin, Tacotundra, jeremyd and 2 others like this.
  21. Jan 12, 2018 at 7:30 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Is that movie on pornhub? Looks interesting.
  22. Jan 12, 2018 at 7:49 AM
    Eclipsed & Floating
    Voluptuous Whitey
    What’s Pornhub?
  23. Jan 12, 2018 at 8:09 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i have at least a dozen situations right now with the day job where that would be a perfect response. however, i'm sure HR and the ombudsman would be calling within 5 seconds of my using it.
  24. Jan 12, 2018 at 8:12 AM
    TXMiamiFan
    Jose
    Have no idea. Lots of members quote it so I just did the same so I can appear to be like the cool kids.
  25. Jan 12, 2018 at 8:12 AM
    TXMiamiFan
    Jose
    Yeah, HR sucks.
  26. May 19, 2019 at 6:08 PM
    jlipp24
    jlipp24 New Member
    Jlipp24
    Tundra TRDPro
    Lift, intake, exhaust and tune.
    Hi Guys!
    New member here. Im experiencing the exact same R to D issue. Toyota has said fluid level is fine. My third trip to Toyota in calendar year. Any updates to the original question by vetteguy?
  27. Jan 25, 2020 at 6:31 AM
    CMcD
    CMcD New Member
    2018 Tundra Crewmax Limited
    New to the forum guys! Specifically looking for people that had the same problem. 2018 tundra with 22K miles bought new. Started about 8 months ago. I noticed that after starting and backing up it takes about 2 seconds to engage the tranny. Then it from R to D it takes 2-3 seconds. If I try to take off quickly there is a shudder then it will go. It doesn't matter if I let it warm up for 20 mins. It happens upon first movement. After say driving for 30 mins the shifting problem is not as significant. For those that might say this is somewhat normal cold again I do let the truck warm up. I also would have to disagree as I have the 2018 sequoia with the same powertrain that will shift without any delay. I've tried to replicate with speedy shifting in the sequoia cold it shifts and engages perfectly. My concern is that this will be a worsening problem. If anybody can speculate what the problem is I will go to Toyota with some type of argument.
    Thanks guys.
  28. Jan 25, 2020 at 6:34 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    If my trans did that, I'd have it flushed. Try some better trans fluid than toyota ws, perhaps this:
    https://www.schaefferoil.com/documents/90-204SAT-td.pdf
  29. Jan 25, 2020 at 7:48 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    I’ve been monitoring the transmission temps on my 2017 and 2019 Tundras for the last couple of weeks while towing. For fun, I hooked the scanner up to the 4Runner this morning and took it for a ride. One thing that strikes me is how long it takes all these transmissions to come up to the “normal” operating temperature. In the winter weather, I literally drove 15-18 miles on relatively high speed rural roads and then was on an interstate for 5 miles before the transmission gets to 190ish on the 2017 or 205ish on the 2019. On “shorter” trips empty, I doubt the transmission ever gets to the operating temp. On the 4Runner, I drove around for 30 minutes this AM and made a couple stops and covered 20-25 miles total on lower speed roads. The transmission temp never got above 125 degrees on the 4 Runner. All that said, I’ve never had any shifting issues, towing or not, in either of the Tundras regardless of transmission temp.
  30. Aug 19, 2020 at 4:23 PM
    blackCat1
    blackCat1 New Member
    Tyler
    Black 2021 Toyota Tundra SR5 TRD sport Crewmax
    5100s up front on middle setting
    my 19 is doing this same thing. R to D there is a shutter then a soft engage. Hard shift from 1st to 2nd, this is more like a slip then a hard engage. Has anyone had any success with toyota on this?
    Thanks
