tranny over heats in 4 hi?
Discussion in '2nd Gen Tundras (2007-2013)' started by wigburner, May 26, 2020.
  1. May 26, 2020 at 12:59 PM
    wigburner
    wigburner [OP] New Member
    09 double cab 5.7
    i recently had my fluids replaced.
    diff, tranny, oil......
    not flushed.
    and two days after i was off road in my normal manner an the tranny started to heat up quickly in 4 Hi. and it has never done this before.
    the mechanic who's a toyota specialist claims he did everything right.
    and couldn't have shorted me on fluid.....
    once it over heated in 4 lo when i was driving too long in 4lo.
    but never since. including last weekend.
    some pitches were steep but not horrible.
    i was wondering if maybe a bit low and the steep pitches caused it to seem low and run hot.....
    any ideas?
  2. May 26, 2020 at 1:41 PM
    Did the idiot light come on, and something telling you it was to hot or do you have a scan gauge?
    Your location has been hot lately, but nothing like the guys out in AZ and CA in the summer.
    Have you tried to pin the thermostat open on the trans? If it still gets hot after that, you might have a transmission going out.
  3. May 26, 2020 at 1:53 PM
    wigburner
    09 double cab 5.7
    i was looking at the gauge below my tach.
    it was below 50 degrees
  4. May 26, 2020 at 1:54 PM
    wigburner
    09 double cab 5.7
    50 degrees out side
  5. May 26, 2020 at 2:12 PM
    How many miles on your 09?
  6. May 26, 2020 at 5:05 PM
    wigburner
    09 double cab 5.7
    175,00
  7. May 26, 2020 at 6:53 PM
    Have you done all the service’s and checks? 175k miles is getting up there if it wasn’t ever serviced properly
  8. May 26, 2020 at 6:59 PM
    wigburner
    09 double cab 5.7
    serviced like my life depended on it,
    it's weird from one weekend to the next.... it happened.
    and right after it was serviced.
  9. May 26, 2020 at 7:11 PM
    What kind of work has it done? Heat is usually generated by excessive slipping. Wonder if your torque converter is going bad?
    15whtrd and jeremyd like this.
  10. May 26, 2020 at 7:15 PM
    wigburner
    09 double cab 5.7
    lots of hiway driving.
    but some off road stuff.
    i did get stuck in the snow a couple of weeks ago.
  11. May 26, 2020 at 7:39 PM
    Did you try rocking the truck out of the snow?
  12. May 27, 2020 at 7:48 AM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    How much Toyota Transmission Fluid did the mechanic use? And yes, did he pin the thermostat open when the transmission got to 115F before checking the fluid level with the vehicle running?
