Tranny drain and fill crush washers
Discussion in '1st Gen Tundras (2000-2006)' started by wildduk, Nov 10, 2024.
  1. Nov 10, 2024 at 9:14 AM
    wildduk
    wildduk [OP] New Member
    Atlanta
    2006 DC 2WD
    About to do a drain and fill, and level check on my 06 DC. For the drain, fill, and fluid level check bolts, are there crush washers I should replace?
    Watched a few YT videos but no mention of them
    Thx
  2. Nov 10, 2024 at 9:56 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I haven's ever replaced them on any of my vehicles.
    Dook55 likes this.
  3. Nov 10, 2024 at 10:13 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Strangely not the case for the earlier year Tundras. All they seem to give out are crush washer replacements even though my original gasket was not.
    FrenchToasty likes this.
  4. Nov 10, 2024 at 10:17 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I helped my 3rd gen friend do a 50k service, his transfer case has pipe thread plugs with 3/8 drive holes, so much easier and less hassle, that’s the only thing I’ll give kudos to
  5. Nov 10, 2024 at 11:49 AM
    gagecalman
    gagecalman New Member
    Maryland
    2006 Tundra DC SR5 4WD 4.7 V8
  6. Nov 10, 2024 at 12:00 PM
    Jack McCarthy
    Bill
    North of Boston
    Sounds typical. You could probably keep reusing the flat washers. First time a tech does it though, consider it gone. They did to mine.
  7. Nov 11, 2024 at 6:37 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    My problem is remembering which way they're supposed to go. They aren't the same on both sides. I don't think it really matters, but there is a correct way.
    Whatever research I did on the tranny drain & fill must have recommended the crush washers, because I have a few of them now. The washer that came off looked like a crush washer too. I know the previous owner did a tranny flush.
