Trailer makes my pro squat ridiculous....
Discussion in 'Towing & Hauling' started by njccmd2002, Sep 11, 2017.
  1. Sep 11, 2017 at 7:01 AM
    njccmd2002
    njccmd2002 [OP] New Member
    2015 White TRD Pro
    Stock
    Recently i have noticed, that my tundra pro squats a lot. did not use to do this, if i recall, but i never measured..
    An empty trailer makes my truck go down, almost two inches. 18 foot trailer, double axle.. Metal and wood...
    If I load a car up, it looks worse, the bumps in the frame are almost 1 1/2 inch away from hitting the bed..
    Is this normal? Still under warranty..
  2. Sep 11, 2017 at 7:11 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    That is a pretty good amount of weight on the rear end of the Tundra, it is normal. Toyota tries to manufacture a good leaf pack that holds weight but still gives good ride quality.
    In my opinion I would recommend jumping on a set of Firestone ride rite Airbags for leveling out the Tundra when loaded down with that trailer. They will help assist in load level capacities up to 5000 lbs no problem and still give great ride quality and stability both empty and loaded.
    Here is a link to them so you can check them out: http://toyteclifts.3dcartstores.com/2445--Firestone-Rear-Air-Bags--07-Tundra_p_380.html
    Let me know if you have any questions at all!
    -David
    BTBAKER, KB Voodoo, T-Rex266 and 3 others like this.
  3. Sep 11, 2017 at 7:47 AM
    njccmd2002
    2015 White TRD Pro
    Stock
    would that be better over a wdh? assuming easy to install. Ill check it out....
  4. Sep 11, 2017 at 7:54 AM
    Toytec Lifts
    Denver, CO.
    Honestly I would recommend the Air Bags first... They are a nice easy install with no drilling required. Should be about a 1-2 hour install no problem
    -David
    mudslinger79 and NewImprovedRon like this.
  5. Sep 11, 2017 at 8:06 AM
    njccmd2002
    2015 White TRD Pro
    Stock
    thanks, appreciated.
    Toytec Lifts likes this.
  6. Sep 11, 2017 at 9:07 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Not to take anything away from Toytec, since those guys are awesome, but another option would be Timbren.
  7. Sep 11, 2017 at 9:08 AM
    Toytec Lifts
    Denver, CO.
    Which we also offer:thumbsup:
  8. Sep 11, 2017 at 9:09 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    well, that's rad. if my deavers start to sag once the bumper goes on, i'll be calling you.
  9. Sep 11, 2017 at 9:10 AM
    Toytec Lifts
    Denver, CO.
    Anytime buddy!
    -David
    smslavin[QUOTED] likes this.
  10. Sep 11, 2017 at 9:41 AM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    Anybody on here have experience with either Sumosprings or Roadmaster Active Suspension on the Tundra to solve this problem?
    Sumosprings:
    https://www.supersprings.com/shop/SSR-610-47/
    Roadmaster:
    https://activesuspension.com/
    I like the Sumosprings because there is no air to leak or have to pump in or out. And I like the idea of the Roadmaster Active Suspension as well, seems like a cool solution.
    Thanks.
  11. Sep 14, 2017 at 4:35 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Another guy here also looking for an airbag alternative.
    Anyone with any experience with...
    -Timbren springs
    -Sumo Springs
    Thanks
  12. Sep 14, 2017 at 4:52 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Get one of those pup trailers that holds the weight for you, instead of putting the weight in the truck or getting air bags. It's a lot less on the truck
  13. Sep 14, 2017 at 4:58 PM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    If your trailer is that heavy, you seriously need to look into a weight distributing hitch. It evenly spreads the weight of the trailer between the truck and the trailer to give you more control and safer handling. Having too much tongue weight in relation to gross trailer weight can cause the hitch of the trailer - and the rear axle of the tow vehicle - to dive, meaning the front of the trailer will head toward the ground, bringing the front of the towing vehicle off of the ground. Obviously, if your tow vehicle dives too far, such as in situations when you need to brake quickly, you'll loose braking traction and steering control of the wheels on the front axle, which can be very dangerous. The opposite is also true of too little relative tongue weight. In those situations, a trailer will be more prone to sway, and it can swing back and forth out of control. Because of these two factors, you can see why finding the delicate balance between tongue weight and gross trailer weight is so vital. Weight distribution hitches can help prevent those dangerous conditions and improve a vehicle's ability to turn, brake and steer, especially in the case of large loads, which can be hard to maneuver in a safe and controlled manner.
  14. Sep 14, 2017 at 5:04 PM
    .....and required over 5000 lbs weight on the Tundra.
  15. Sep 14, 2017 at 5:10 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I've gone through this, and suggest you study options carefully if you enjoy the silky smooth ride our pros come with.
  16. Sep 14, 2017 at 5:22 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    He boss chimed in... tell em Chris!! :cheers:
    Ike74 and jfrd30 like this.
  17. Sep 14, 2017 at 6:13 PM
    be77solo
    be77solo New Member
    Unfortunately not much feedback on this site with alternative setups it seems.
    Sumo Springs were great on my Tacoma instead of airbags, loved them. Was hoping to see some feedback here Tundra wise (particularly because we have 3 weight capacity options of Sumo Springs) but it appears they aren't popular on this board. I'm also quite intrigued with the Roadmaster setup, which others love on different sites. But, still need to talk to them and research further. There is a dominating voice here in this area, and he drives a Chevy HD, that went bigger truck to resolve tow issues. He's absolutely right, and very helpful, but we drive Tundras. I drove a F350 Diesel for years, towed great, but you couldn't pay me to go back to a similar rig. Finally got tired of fixing it so sold it. I went slightly smaller gas truck and just want to make it work when I tow. Guess we each have our own key issues. ;)
    I'll research further and report back what I find and go with regarding the standard "firestone airbag" response.
  18. Sep 14, 2017 at 6:26 PM
    Kevin1741
    Kevin1741 New Member
    Timbrens work ok but you need a bit of weight on them before they work whereas the air bag can be filled to meet your load and keep the exact level you are looking for. The firestone system works well and if you opt for the onboard pump you can adjust on the fly.
  19. Sep 14, 2017 at 7:15 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Will this work with CB +3 shackles? I think it lifted my rear about 1.5-1.7".
  20. Sep 14, 2017 at 10:14 PM
    Please, go buy some Sumo Springs then. There isn't anyone on here stopping you. Hell, in fact I would buy the Sumo Springs over an airbag setup any day. If they worked well on your Tacoma, they will be awesome on your Tundra. I apologize this site has not reviewed the Sumo Springs. Tundratalk has a few threads about them with great reviews. I found that with a quick google search. I would link it, but I don't want to...
    So since you did single me out with the Chevy HD comment (my truck is a GMC FYI), allow me retort sir:
    I have been pretty reserved these past few months about towing....usually single comments like in this thread. To be honest, if someone wants to overload their truck or pile it up off a mountain side, I really do not care. Seriously, if it doesn't impact me, no fucks given.
    Reading directions, using simple 3rd grade math, and having the aptitude to actually put this all into play shouldn't be this hard.
    So this will be my last post about towing. I will stick to the green room and off topic sections, because like I said before...no fucks given. I'm tired of getting comments about my truck selection, even though being a rather large Toyota/Tundra supporter.
    So future towing questions should be directed @be77solo , our new resident towing expert, because he owned an F350 and towed for years. Sounds legit.
    Thank you and have a great night.
  21. Sep 14, 2017 at 10:54 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Dang it Chris.... seriously no lie I was about to hit you up on towing because it looks like duramax/Allison is in my near future..Mamma just hit me up and suggested we get a big'o travel trailer...Sooo before you go kimosabe..did you airbag yours? I'm tryna hurry before you nuke this thread.
    ColoradoTJ likes this.
  22. Sep 15, 2017 at 1:23 AM
    I replied to your PM since we have chatted before about this. No worries.
    NewImprovedRon and Pudge like this.
  23. Sep 15, 2017 at 1:28 AM
    karlsters
    karlsters New Member
    2017 tundra limited doublecab
    i just posted a review on the Summo springs in another post. I was contemplating between bags, timbrens, and Summo. Eventually went with the Summo springs because of the unloaded drivability. Seem to be a good product. Ride is great unloaded ( don't even notice them except much less dip when cornering) and they did help a lot with the rear end squat when hooked up to my TH. I have a 30 foot toy hauler with the WDH. I posted a pic under the other post. Installation only took about 15 minutes and most of that time was just getting my 50 year old fat ass under the truck. I would certainly recommend the Summo springs. Can't speak to the long term durability but they seem to be a quality product.
    Y0TA PR0 and be77solo like this.
  24. Sep 15, 2017 at 6:06 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    @karlsters thanks for the response.
    I know there are many opinions on towing and just as many facts. I also understand that it comes down to simple math and load management/placement over the trailer axles. I have been hauling ag tractors, mini-ex, skid steers, and too much other BS over the last 12 years for work, I am very aware of what to much or to little tongue weight will do. I haul boats at work and on my personal time as well. My main inquiry on this topic for the Tundra is because I am planning on a 20'-22' toyhauler in the next few months. This will get pulled 3-6 hours from home 5-8 times a year.
    I do not want airbags for the simple reason that I do not want a compressor, air lines, rubber bladders, and the maintenance/wear-tear that comes with them. If I was hauling a camper or equipment trailer once a month or more then I would reconsider, or I would buy a 1 ton. I understand the physics of a trailer with too much tongue weight wanting to dive and what that will do to the handling of the tow vehicle. That is why I am so interested in the Sumosprings or Timbrens. They offer that extra assurance that after an inch or so of sag there is something there to help keep the truck and trailer under your control. I am not going to load 2000lbs of sand/drywall/shingles or otherwise in my bed and rely on these to take the load. I am also not going to put excess tongue weight on the truck and ask these to handle my poor loading. Its cheap insurance to help the rear of the truck not sag so much. I know it will still sag, but these will help. Whatever I get for a toyhauler will also have a load distributing hitch with sway control. I already have a brake controller and the factory Toyota tow package.
    I am just looking for opinions on the Timbrens and Sumo Springs. I realize this was a 3rd Gen/Pro thread, but load leveling and control is universal.
  25. Sep 15, 2017 at 8:26 AM
    be77solo
    be77solo New Member
    Perfect, thanks. Do you remember which set you installed? They have 3 different capacities (blue, black, yellow) which I think equates to 1000, 1500, and 2000lbs capacity. Not sure if they are physically any different height wise or anything.
    I had the blue ones on my Tacoma, and like you said, super easy install and very happy with them when loaded. But, on the Tacoma they actually ride on the Summo springs all the time (raises the rear of truck about 5/8" when installed), so when empty it really makes you feel every bump in the road.
    Sounds like your Tundra isn't riding on them all the time when empty, which is great to know and what I'm looking for.
    I'm in the same boat as @OBXTundra and just looking for a little help with squatting when hauling a load or a loaded utility trailer etc like the OP. I often don't know what I might have to occasionally go pick up on a given day with my job, so the always there and ready zero maintenance summo springs or comparable option has more appeal than having to have access to an air compressor for airbags. If I was mission set on a long trip towing a big travel trailer long distances, my goals/needs would be different.
    @ColoradoTJ , my apologies man as you are great around here and always helpful. I reread my post and wasn't my intent to single you out, but I did just that. And yeah, I do want to buy the Summo Springs or comparable, was just looking for feedback on which of the 3 weight capacities have worked well for others and mentioning them as an alternative for the OP and his sagging Pro. Also intrigued by the Roadmaster setup, and I have found one thread on another forum talking about them on a Tundra, but not much else. They do appear to be local to Charlotte, so maybe I'll just stop by and check out their operation in person. Thanks for the feedback, I hope no hard feelings. :cheers:
  26. Apr 29, 2018 at 8:36 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Hi..
    My towing experience: 1900lb 10ft popup and a 3200 lbs,19 ft rpod and was done with a trailblazer extended cab.
    This is my first pickup truck and 30ft tt.
    With about 500lbs on the bed and about 6500lbs loaded 30 fot tt with wt is sagging bad. I like the suspension when unloaded and would like to keep it if possible. I have done some reading and this is what I found so far:
    1. Air bags will fix the sagging but will make the truck "bouncy" when unloaded(not sure if it means it will make a stiffer ride)
    2. Summo springs is a possible solution but not sure how much of the sagging will prevent and how does 1000,1500 and 2000 lbs translate to 7000lbs load.
    3.shackles, could not find a clear explanation of how they help with the sagging or how it will affect the unloaded suspension but supposedly it helps.
    4. TRD sway bar seems to be a popular item around here. I can install anyone of these but not sure which one will solve my problem.
  27. Apr 29, 2018 at 9:05 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If you are happy with the unloaded ride quality, I wouldn't mess with the springs. Air bags would solve the problem without negatively impacting unladen ride quality.
    Coolhardy likes this.
  28. Apr 30, 2018 at 1:13 AM
    15'TeRD
    15'TeRD New Member
    Tony
    San Diego
    15 TRD Double Cab
    Nothing special
    Look into a WDH .. towed my 21' toy hauler no problem with no squat
  29. Apr 30, 2018 at 6:39 AM
    xj2202009
    x
    Lutz, Fl
    OBXTundra likes this.
  30. Apr 30, 2018 at 10:03 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    That Curt system looks nice. Very similar to my Equilizer. Nice thing about both of those hitches is that you can backup with them and it's sway control built in.
    I have SumoSprings. 1500lb capacity. They work exactly as advertised. Between the WDH and the Sumosprings I do have slight sag, not nearly as much as without. But the truck remains almost level, a lot of the weight is pushed to the front axle.
    Y0TA PR0 likes this.
