Trailer Lighting Issues
Discussion in 'Towing & Hauling' started by DaHorns, Nov 3, 2020.
  1. Nov 3, 2020 at 3:43 AM
    DaHorns
    DaHorns [OP] New Member
    2013 Tundra
    I have a 2013 Tundra that I haul a landscape trailer with. When I turn on my lights I don’t seem to get power to my trailer running lights. The brake lights work, turn signals work but no running lights. Any help would be very appreciated.
  2. Nov 3, 2020 at 6:48 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Typically when I have had a trailer where some lights work but other do not, it has always been a bad/dirty connection- unless a bulb is bad. Clean the plugs/connections on the truck and trailer. Get them really clean, if you can see any dirt or crud it could be causing an issue. Give that a shot and see if it resolves the issue. While you are in there see if any of the pins or tabs are bent.
    Tundyfundy and mountainpete like this.
  3. Nov 9, 2020 at 9:40 PM
    Toekneewin
    Toekneewin New Member
    Tony
    2020 Super White TRD Sport
    Did you resolve this? I'm having a similar issue with my 2020. No running lights and no left turn.
  4. Nov 9, 2020 at 10:58 PM
    SouthWestGA
    SouthWestGA New Member
    I had a bad towing fuse under the hood once that caused issue with trailers
  5. Nov 10, 2020 at 3:52 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    My issues have always been the trailer too.
    OP. Check where wires go into back of the light for bad connection. If it's one upstream nothing behind it will work either. At least on mine.
    Sometimes I have to rotate the bulb just right to get brake lights and running lights to work correctly. At the back of the bulb are two bumps and those need to sit right on the metal tabs in the light housing.
  6. Nov 10, 2020 at 4:37 AM
    slongo
    slongo New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    Do you have tailights ? If so its definitely in the trailer wiring
  7. Nov 24, 2020 at 10:14 PM
    Toekneewin
    Tony
    My problem was the 30amp fuse underhood and whoever wired my trailers 7 pin connector was color blind/couldn't read.
