trailer light problem from the truck side
Discussion in 'Electrical' started by k9cop, Jun 24, 2024.
  1. Jun 24, 2024 at 12:54 PM
    k9cop
    k9cop [OP] New Member
    terry
    2010 toyota tundra 5.7
    good afternoon, I have a problem with the wiring on the truck side. I only have tail lights on the trailer no brake or turn signals. I have checked the fuses under the hood and under the dash and all good. I replaced the plug thinking that was the problem and nope still not working. I used another truck and all the lights work, any ideas ? thanks
  2. Jun 24, 2024 at 12:59 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Did you replace your interior lights with LED’s by chance? Sometimes, believe it or not, that throws the trailer lighting off…..try replacing the interior lights with the oem bulbs and see if your problems persist. You should also check all of your grounds and clean thoroughly
  3. Jun 24, 2024 at 1:15 PM
    k9cop
    terry
    no I haven put LED's in, this is driving me crazy but thank you
  4. Jun 24, 2024 at 1:30 PM
    shawn474
    MoCo, Maryland
    Even if the fuses look ok you may want to check continuity; sometimes they can look fine but be bad. Might be worth testing new good fuses with the ones that coincide with trailer wiring
