Trailer hitch rust - cure?
Discussion in 'Towing & Hauling' started by Borgs, Aug 28, 2017.
  1. Aug 28, 2017 at 6:42 AM
    Borgs
    Borgs [OP] New Member
    PA
    What do you all do to prevent your hitch from rusting? It's bound to happen, anything to slow it down? Or just file/sand and rustoleum the heck out of it ever year?
    ColoradoTJ likes this.
  2. Aug 28, 2017 at 7:20 AM
    Quebec
    Quebec New Member
    I've used Ospho. It didn't have any effect.
    I've applied Rust Bullet. It started flaking in under a year and got it all over me in the process.
    Use the hitch once a year? You'll have bare metal ripe for rust.
    I'm not a fan of rustoleum anything, so I would just prep, mask off and light Krylon coats once a year if it bugs you.
    Black Wolf and Bob like this.
  3. Aug 28, 2017 at 7:54 AM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    They make a frame paint called POR which I've heard good things about in the Jeep world. Jeep owners might not be quite as discerning as Tundra owners though, lol. I used to be a Jeep nut so I'm one of those people.
    Good powdercoat might do the job also.
    Borgs[OP] and Bob like this.
  4. Aug 28, 2017 at 8:57 AM
    I use Krylon.Seems to do the trick for me.
    Borgs[OP] likes this.
  5. Aug 28, 2017 at 9:00 AM
    Borgs
    PA
    Thanks. It does bug me. I am OCD that way.
  6. Aug 28, 2017 at 9:34 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Are you talking about the receiver on your truck? or the hitch and/or ball?
  7. Aug 28, 2017 at 9:47 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    POR15 is a great solution and a basic kit can be had on Amazon for about $25. Clean up the rust scale, apply the POR15 and then overcoat with something like 3M 08881 or Eastwood chassis black and your rust problems will be gone.
  8. Aug 28, 2017 at 9:59 AM
    PMG
    PMG New Member
    Be sure to be in a well ventilated area. Por 15 stinks but works.
  9. Aug 28, 2017 at 10:41 AM
    Borgs
    PA
    I am talking about the receiver.
  10. Aug 28, 2017 at 10:49 AM
    Don't listen to these jokesters. You just need to do a few things:
    1) Take more vacations
    2) Use truck on said more vacations towing toys.
    See, your hitch will always be shiny.
    Solving problems one post at a time.
    Yeah, POR15 is some good stuff, just like the other good men stated in this thread.
    duece292 and NewImprovedRon like this.
  11. Aug 29, 2017 at 8:29 AM
    Redbeard321
    Kind of hard to keep it spotless since the hitch will rub inside the receiver. You can try a thin coating of grease to prevent rust. Paint will most likely just be rubbed off by the hitch.
  12. Aug 29, 2017 at 9:46 AM
    Borgs
    PA
    It's inevitable. I know. It's a new truck, I Am just trying to slow it down - so it looks pretty as long as possible.
  13. Aug 29, 2017 at 9:49 AM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    Fluid Film - Apply once or twice a year. Spray it over all your metal surfaces underneath the truck. EXCELLENT product.
    ColoradoTJ and NewImprovedRon like this.
  14. Aug 29, 2017 at 10:13 AM
    Borgs
    PA
    I have seen this. Really works?
    NewImprovedRon likes this.
  15. Aug 29, 2017 at 10:26 AM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    Yes, I spay it over all the metal parts both spring and fall, keeps everything nice and protected especially if you live in a cold weather state like I do (Utah). It is a lanolin based product so it will not effect wiring, rubber hoses and gaskets, sensors, etc. although I try to just keep it on the metal.
  16. Aug 29, 2017 at 11:04 AM
    Quebec
    Quebec New Member
    *However for a while it will make your truck smell a bit ................................... sheepy.
  17. Aug 29, 2017 at 11:20 AM
    Living in the rust belt, your doing the right thing.
  18. Aug 29, 2017 at 2:25 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Not the prettiest solution but I hot dip galvanized every draw bar I owned when I was in that business years ago. No rust except the stains transferred from the inside of the receiver.
