Trailer Brake Error
Discussion in 'Towing & Hauling' started by Crow52LA, Apr 16, 2021.
  1. Apr 16, 2021 at 10:46 PM
    Crow52LA
    Crow52LA [OP] 4x4 sport horns in the air
    North East Los Angeles
    19 MGM SPORT CREWMAX 4x4
    Gangster
    Need assistance. My fiancé has a 2019 Toyota Tundra and as I was driving it home these errors came out. We haven't towed anything recently so not sure why this error popped up all of a sudden If anyone could help that would be great, not sure of I should take it into the dealer or if there's an easier solution. Thanks in advance
    - CrowsLady52LA
  2. May 14, 2021 at 11:28 AM
    Redrider29
    Redrider29 HARDTRD
    Mitch
    2019 SR5 Crewmax TRD Offroad 4x4 Cement
    Paint matched mirror caps, grill surround, hood bulge, and Bumper Shellz Wireless phone charger in center consule TRD rear sway bar Black painted TRD off road wheels with TRD center caps Black emblems TRD air filter Tyger roll up tonneau cover Extra USB plugs in cab TRD Pro grill Paint matched Bumper Shellz 1.25" Spider Trax spacers Lamin-x fog light covers yellow-removed Diode Dynamics SS3 amber fogs Bilstein 5160 rear shocks DIY bed rail system AJT TSS relocation bracket AJT interior chrome delete bits and pieces Caliraised LED 32" light bar bracket GG Lighting 32" light bar
    Same here. Exact message. Same year truck. Almost same miles. Anybody??
  3. May 14, 2021 at 11:35 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Take it to the dealer as it’s still under warranty. The PCS could be weather related - was there heavy rain at the time it popped up? The trailer brake error could be a software issue……worst case would be that maybe the culprit would be rodent damage or something similar.
    Have you done any mods to the truck?
    Huck23 likes this.
  4. May 14, 2021 at 11:35 AM
    timsp8
    NY
    Take it to the dealer. There was a recall on the pcs where they put some silicone on it and reflashed it. Also check your radar isn’t dirty or it wasn’t raining really hard. You’re under warranty so get it fixed correctly.
    Huck23 likes this.
  5. May 14, 2021 at 12:23 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Thought: I don't think TSB 0036-19 applies as it says error and not "disconnected".
  6. May 24, 2021 at 10:38 AM
    TigerTanker
    TigerTanker Tyranny doesn't leap, it creeps
    Tacoma WA
    2016 White Platinum Edition Tundra
    none so far
    I am now about to take my 2016 Platinum in for the THIRD time for the "Brake Controller Error" message. Help!
  7. May 24, 2021 at 10:56 AM
    mountainpete
    What is the full message? Take a pic please.
    When does it happen? While towing, before, car wash?
    The community will help but you need to post more info.
  8. May 24, 2021 at 1:13 PM
    TigerTanker
    Tacoma WA
    none so far
    In a nutshell, I got the error in the first pic of this thread along with flashing 4w hi lo signs, flashing exclamation too along with traction control, and abs light. Would restart every 1/10th of a mile on a restart, and shortly after a surging feeling in the brakes like the abs system. It started after I was towing a non braked trailer, but I pushed the trailer button on my dash. I suspect it was expecting a corresponding braking system on a trailer. The brake performance after the strange surge feeling was normal, and I didn't feel at risk. But I was on the beginning of a 5000 mile drive... Took it into my dealer when I got home after a month, this started on 4/15/2021. They first said it was a dirty electrical connection, but the light came right back on, so back to the dealer it went. They then said it was something to do with some sort of sensor miscommunication. Then it was fine for 200 miles, but came on yesterday afternoon with no trailer while on a long dry trip over the mountains. This morning, no lights on, but I decided to check this issue out here on this forum. So now I disconnected the battery and have taken a 20 minute drive with no issues. I own a 2016 tundra platinum
  9. May 24, 2021 at 1:24 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Aha!! Der KoenigsTiger! 88mm of battlefield domination; command of everything surveyed from yonder heights.
    Truly the origin of fahrvergnügen.
    TigerTanker likes this.
  10. May 24, 2021 at 1:36 PM
    TigerTanker
    Tacoma WA
    none so far
    hagrid[QUOTED] likes this.
  11. May 27, 2021 at 8:14 AM
    TigerTanker
    Tacoma WA
    none so far
    And today I'm going to the dealer for the 3rd time regarding the Brake Controller error lights. When the car starts, sound and feeling from the front end has led me to believe that the ABS system and Traction Control are being turned off. It's raining today and I could lock up the wheels when coming to a stop. I was supposed to haul a trailer today to move furniture... can't now due to risk. This is getting rather frustrating.
    If anyone knows about the history of this problem, by all means, please chime in and let me know. Also, what can I do as a consumer should this not get fixed this third time?
  12. May 27, 2021 at 10:26 AM
    mountainpete
    This sounds more and more like a wheel sensor issue. Ideally they can track down which one and replace it.
    As a consumer, you don't have any additional support unless the truck is still under warranty. Sometimes it takes time to fix tricky things and your truck is 5 years old.
  13. May 27, 2021 at 4:09 PM
    TigerTanker
    Tacoma WA
    none so far
    Dealer just called me. They say the rear differential was grinding inside/failed, and oil and metal shavings covered the rear wheel sensor. They say it's $4,000 to replace.
    This is the only dealer I've taken it in. My friends say the rear differential requires servicing. The truck has 100k miles on it, not sure this dealer has done anything with the rear diff for servicing.
    I'd taken the rig in for an oil change before my big road trip of 5k miles where this issue first flared up.
  14. May 27, 2021 at 4:13 PM
    timsp8
    NY
    You could get new gears and an LSD installed for less than that. Then replace the wheel speed sensors yourself.
  15. May 27, 2021 at 4:25 PM
    TigerTanker
    Tacoma WA
    none so far
    I've asked for the history of my service there(only dealer that has touched the rig), and specifically any history of review of the rear differential. I've asked for the service manager to review and have me come in for an appointment for discussion. My mechanic friends suspect that the rear differential was never serviced.
  16. May 27, 2021 at 4:33 PM
    timsp8
    NY
    Could be. Have you owned it since new? Have you ever specifically asked for a rear diff oil change? I’m just asking because if you take it in and just ask for service, they probably gave it to the new guy and only said change the oil. Seems people now do the bare minimum to not get fired. Then the 2 Bobs promote them to manager.
    Can you get a carfax for it? See if it matches dealer records.
  17. May 27, 2021 at 4:35 PM
    TigerTanker
    Tacoma WA
    none so far
    It was a dealer vehicle, had 10k miles on it when I bought it. No, I have never specifically asked for a diff service.
  18. May 27, 2021 at 5:26 PM
    mountainpete
    Let’s separate the issues here. Differential vs sensor.
    Yes, shavings in the diff is bad. But have you actually had issues with it? Is the truck suddenly undrivable?
    Once the replaced the fluid and cleaned the sensor, did your problem go away?
  19. May 27, 2021 at 5:29 PM
    mountainpete
    And maybe start a new thread in the 3rd Gen section specifically about the diff issue.
  20. May 27, 2021 at 6:56 PM
    TigerTanker
    Tacoma WA
    none so far
    They sent me some pictures, I 'll post up later.
    This appears to be a dealer that may have been negligient in servicing a vehicle. I've been going there every 4 months for about 5-6 yrs, and followed their advice as instructed. We shall see. I have a few unanswered messages I have sent them. Promise to keep everyone posted on this. I never, ever once, ever declined a service... The entire point of regularly going to a dealer is to keep your vehicle properly serviced and in tune with the suggested maintenance.
  21. May 28, 2021 at 1:43 PM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    Does your dealer supply a completed "checklist" with the service record/invoice?
    Reason I ask is I had a similar situation with a Ford dealer that I had taken the truck to for every service since new. During an oil change they said I needed new rear brake rotors. And I did. The pads had scored the rotors. I asked why low pad thickness wasn't caught the previous oil change when the technician noted on the "checklist" the rear pads were in the middle of their expected life span.
    Same as you, my position was I bring it here for proper preventative service and a brake pad gives plenty of warning, if properly inspected, long before it trashes a rotor. After a brief meeting in the Service Managers office, I paid their "cost" for one rotor and they ate the rest of the parts and labor.
  22. Aug 19, 2024 at 3:39 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Hello sorry I just happened to see this thread but I am having the same issues and I only have 36K on my truck. Is there any more resolution to this issues ? Thanks
