Trailer brake error
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yammie72, Jan 5, 2023.
  1. Jan 5, 2023 at 7:57 AM
    Yammie72
    Yammie72 [OP] New Member
    2007 and 2013 Toyota Tundra
    Trailer brake error come up on display. 4lo and 4hi, abs, traction control, ! all lighted up. Any ideas whats causing this? 2017 trd
  2. Jan 5, 2023 at 8:00 AM
    2mchfun
    First off, do you have a trailer plugged in?
  3. Jan 9, 2023 at 11:41 AM
    kevine0001
    kevine0001 New Member
    Kevin
    I'm having same issue; from what I've read and been told (cousin was a Toyota tech), it's either an axle seal leaking onto ABS sensor, possibly needs an update on software, or something else. But those are the two main things I've been able to find. I've been told the axle seal job is a PITA. Need a press, completely new parts (none of the old parts are re-useable) and needs a press. Mechanic told me probably $800-$1000 ($550 labor/$300+ for parts).
    If anyone has any new info to add, would love to hear it.
