Trading up into a Tundra from Tacoma
Discussion in '2.5 Gen Tundras (2014-2021)' started by 10a453, Oct 27, 2015.
  1. Oct 27, 2015 at 5:58 PM
    10a453
    10a453 [OP] New Member
    2014 Tacoma TRD Sport
    i have a 2014 Tacoma double cab with the 4.0 V6. I need more interior room so the Crewmax is ideal. Am I going to see a huge increase in gas cost or not that bad coming from the Tacoma. Thanks for the feedback
  2. Oct 27, 2015 at 6:15 PM
  3. Oct 27, 2015 at 6:30 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    What's your milage now?
  4. Oct 27, 2015 at 6:30 PM
    Virgils12
    @Sean266 you think the bd's gonna help your milage?
  5. Oct 27, 2015 at 7:20 PM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    In all honesty, as long as you keep stock tires and stuff, you'll probably get 17-18mpg. So I'm guessing you'll lose 2-3 from what you get with your Tacoma. Really not that bad. I have a "rock warrior" with bigger tires and I usually get 14-15, but have gotten as high as 17.
  6. Oct 27, 2015 at 8:17 PM
    Some have reported an increase...we'll see.
  7. Oct 28, 2015 at 5:58 AM
    chphilo
    chphilo Tundra addict
    Western PA
    The mpg decrease is definitely not huge. Mpg sucks for all trucks. At least with Tundra you get extra room and power.
    If you are worried about the mpg, keep your truck stock. Tundra stock configuration has been fine-tuned for efficiency. I was able to get 18-19 mpg on highway/rural roads easily. Then I lifted the truck and got heavy tires. The mpg has never been the same since.
  8. Oct 28, 2015 at 8:21 AM
    mgh-pa
    mgh-pa Perpetually a New Member.
    2016 Tundra DC SR5
    I came from a 2005 AC Tacoma on 265/75 Duratracs to my DC 5.7 4x4 bone stock. Only have about 600 miles on it, but I can't eek out more than 15.5mpg on the same commute that my Tacoma would get 18-18.5mpg in all day long. So about 3mpg difference.
  9. Nov 3, 2015 at 12:08 PM
    rowdydaoudy
    rowdydaoudy New Member
    David
    2016 Tundra
    ^I'm with him. Put 200 miles on my 2016 CM 5.7 4x4 and I havent gotten is past 15.5mpg. I am about to put my lift and 35's on it this weekend so that will get shot.
