Trading Ram for Tundra
Discussion in 'New Member Introductions' started by NewToTrucks, Sep 20, 2023.
  1. Sep 20, 2023 at 6:02 AM
    NewToTrucks
    NewToTrucks [OP] New Member
    2023 Ram 1500
    Hi, I've had Jeeps for years, but now I need a full-sized pickup truck capable of hard work on a farm. It needs aggressive tires (with a studded set for VT winters) and spacers, but I don't want it lifted. (My current Jeep is, and oh man, never again.) Unfortunately, I disregarded everyone's advice and bought a Ram in February before realizing it's essentially a luxury car and incapable of almost any task.
    This is what I think I want:
    TRD (need that skid plate)
    P275/55R20
    V8 (w/o hybrid)
    1.5" Spacers?
    Any suggestions? Thank you in advance for your advice!
  2. Sep 20, 2023 at 6:05 AM
    Why spacers?
  3. Sep 20, 2023 at 6:09 AM
    NewToTrucks
    2023 Ram 1500
    I guess mainly for looks, since it won't be lifted.
  4. Sep 20, 2023 at 6:15 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! No need for TRD Pro just for the skid plate. You can add a skid plate yourself very easily.
    1lowlife likes this.
  5. Sep 20, 2023 at 6:44 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Define "hard work on a farm".
    TRD4x4Liberty likes this.
  6. Sep 20, 2023 at 8:45 AM
    NewToTrucks
    2023 Ram 1500
    'Work on a farm' means being able to drive up to the top of a steep, uneven ridgetop field which has been mowed and bundled into hay bales, fill up the bed and get back down to load them in the barn for the winter.
  7. Sep 20, 2023 at 8:47 AM
    NewToTrucks
    2023 Ram 1500
    Doesn't TRD include other things, like different shocks?
  8. Sep 20, 2023 at 8:51 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Yea….sounds like you actually need an F-250 FX4 or 2500-3500. Those in stock form will cover your needs and are actually designed for hard work.
    Devcom and Rodtheviking like this.
  9. Sep 20, 2023 at 9:03 AM
    NewToTrucks
    2023 Ram 1500
    A 2017 Tundra did it. Slowly and carefully, but it did it repeatedly. And does every year.
  10. Sep 20, 2023 at 9:24 AM
    NewToTrucks
    2023 Ram 1500
    And Ford or a bigger ram would do it? I've sworn off Ram, and I'm not a Ford fan.
    I'm coming to Toyota for a couple reasons. First, I think it's a better product than anything I've seen or driven. Second, I've heard they have customer service.
  11. Sep 20, 2023 at 9:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    2017 or earlier SR5 TRD Offroad will do that. 2018-2021 is good, too, but perhaps needs a trans.cooler.
  12. Sep 20, 2023 at 9:29 AM
    yakeng
    I’m just saying that Toyota doesn’t make a heavy duty option that is more geared to farms.
  13. Sep 20, 2023 at 9:30 AM
    NewToTrucks
    2023 Ram 1500
    What is a trans cooler?
  14. Sep 20, 2023 at 9:32 AM
    NewToTrucks
    2023 Ram 1500
    Yakeng, I appreciate your advice and the explanation. Since I'll also need to use it for commuting between Boston and Vermont for the time being, I probably shouldn't go larger than a tundra.
  15. Sep 20, 2023 at 9:33 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Auxiliary transmission cooler with its own thermostat that Toyota took from Tundra in 2018. Good to have if you actually put your truck to work.
  16. Sep 20, 2023 at 11:02 AM
    NewToTrucks
    2023 Ram 1500
    Vtl - thank you so much. Thank you all for your input and advice.
  17. Sep 20, 2023 at 11:56 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    It does, but you only mentioned the skid plate originally. Your search will be simplified if you don't limit yourself to a TRD Pro. You can replace the shocks yourself (or have them replaced).
  18. Sep 20, 2023 at 12:03 PM
    NewToTrucks
    2023 Ram 1500
    Awesome tip, thanks. Maybe I shouldn't limit the search to 20" wheels either. I could always upgrade those too.
  19. Sep 20, 2023 at 12:08 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    The big GM gas truck seems to be a good choice,, if you are hauling hay and loads around the farm in Winter, I would look at the big GM gas truck. Gas so you do not have to worry about diesel in winter. They look pretty nice too?:)
    I like my Tundra but if I lived on a farm and had harsh winters it would be that 6.6 2500 GM truck. They haul enormous amounts and the payload is up there too.:)
    I love the room for driving in the Tundra and is perfect for around the house projects and help out friends that need a PU full of lumber or what ever.
  20. Sep 20, 2023 at 4:10 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Except it's still a GM. Unlike a darn boring V8 Tundra. Nothing happens to it.
  21. Sep 20, 2023 at 4:22 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Get with the times, gang. V8 is so ancient. 3rd gens run exceptionally reliable and efficient v6 with 2 turbos.
    Black@Blue19 likes this.
  22. Sep 20, 2023 at 4:39 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Maybe look for a Gen 2 or 2.5 Dbl Cab Long Bed (8ft) Tundra. More payload than Standard bed Dbl Cab or Crew Max Short Bed. This with 5.7 and 4wd should work well on the farm.
  23. Sep 20, 2023 at 4:44 PM
    Black@Blue19
    Ken
    SE Texas
    You don’t have to convince me I could give to shakes. The Tundra does what I want. I do know lots of farmers and I do not know one that had a Tundra? That might have changed but I doubt it. They own Chevy, Ford, and Dodge products in that order. They trash em out in a year or two and then go buy another one.:) A hand full actually try to take care of their vehicles but they own another truck or car to go places in, like church and Texas in the winter. Tundras are good for 4 wheeling in expensive trucks and taking long cruises having lots of room and in my case having a great sound system to listen to on said drives!:) I can’t remember ever seeing a Tundra in a commercial as a Farm truck? It is what it is I have never said anything bad about none of the vehicles,,,,,, except a Chevy truck that I traded for my first Tundra in 20??
  24. Sep 20, 2023 at 4:55 PM
    PermaFrostTRD
    Northern NY
    TRD Pro has a decent skid plate, TRD off road package has a garbage skid plate. Much better aftermarket options (RCI is great and popular around here.)
    An 18” wheel will give you more rubber and to which you can air down and have better traction when doing “farm stuff”. 20” wheels are for parades.
    Stick to model years 2007-2021. Search 2nd Gen and 2.5 Gen forums here as there are many valuable threads highlighting differences between the generations, model years etc. and benefits of one year vs a different year. If you’re looking new plush creature comforts with less mileage but still can do “farm stuff” look at 2016-2018 (38 gal fuel tank, led headlights, still transmission cooler - 2019 is when that was eliminated)
    This will worsen turning radius, possibly require trimming and cutting body mounts etc. I know you said you want “the look” but you’d be better off with a new wheel with a little more width and less offset (25mm is commonly recommended as the “sweet spot” for our trucks).
    my personal opinion is spacers are goofy looking. But it’s not my truck - let er rip if you want.
    Also, welcome from NNY.
  25. Sep 20, 2023 at 5:03 PM
    EmergencyMaximum
    ZPhilip likes this.
  26. Sep 20, 2023 at 5:05 PM
    Black@Blue19
    Ken
    SE Texas
    Woo Hoo one commercial very good!!! One maybe that is why I missed it.
    That’s funny:)
    I’ve seen a lot in my 60+ years here on earth but I do not remember that one. All though my memory ain’t as good as it used to be either. Plus the fact that someone went and searched for it?
  27. Sep 20, 2023 at 5:15 PM
    Black@Blue19
    Ken
    SE Texas
  28. Sep 20, 2023 at 5:52 PM
    Welcome from NY.
  29. Sep 20, 2023 at 6:25 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from TX. Do the skid plates and call it a day
  30. Sep 20, 2023 at 8:35 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You'll be much better off with 18" wheels for farm and off road work.
