Tractors...
Discussion in 'Off-Topic Discussion' started by ColoradoTJ, Sep 27, 2017.
  1. Sep 27, 2017 at 12:44 AM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    As we look around these neighborhoods, finding a home to fit our needs, one thing has been very obvious to us...everyone has tractors of some sort.
    Roads need repaired a lot, mowing duties on 2-5 acres of not so flat land can be fun, snow removal to main roads (which can be considerable distance) where the typical garden tractor just doesn't get the job done, or at least doesn't last long.
    So I am looking for what experiences you all have with certain brands.
    What I know so far:
    John Deere, Kubota, Massey Ferguson are pretty decent tractors.
    Here has what I have seen mostly around here.
    https://cosprings.craigslist.org/grd/d/2008-massey-ferguson-5455/6295760708.html
    https://cosprings.craigslist.org/grq/d/used-kubota-l2800dt-4x4-front/6315094060.html
    14crwmaxltd, P-Factor and T-Rex266 like this.
  2. Sep 27, 2017 at 1:34 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What you trying to do chris?
    GNTundra likes this.
  3. Sep 27, 2017 at 1:59 AM
    Booney likes this.
  4. Sep 27, 2017 at 2:27 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I wouldn't rule out Mahindra or New Holland either. Dealer support is one of the biggest concerns they all break and if the closest dealer is 4 hours away you're not going to be happy.
    Plus whatever size you think you need, go bigger an overworked machine isn't good.
    usmchawk and ColoradoTJ[OP] like this.
  5. Sep 27, 2017 at 3:49 AM
    Boondoc89
    Boondoc89 Shit happens when you party naked
    Doc
    '17 mgm DC TRD 4x4
    No mods
    My dad bought a Mahindra about 5 years ago. That tractor has been his favorite child since then lol. But in all honesty in those 5 years he's hardly had any problems with it. Only a couple minor things like grease zerks not taking grease.
    Like what @Festerw says. Buying a piece of equipment from somewhere a couple hours drive is a bitch. Luckily we have a Mahindra dealer 5 minutes down the road. I think that was a huge selling point for my dad
    ColoradoTJ[OP] likes this.
  6. Sep 27, 2017 at 4:50 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I have heard great things about Mahindra as well as Kubota. My friend who does hardscapes has a compact Kubota with front end loader. It is going on 10 years old and has had zero maintenance issues, outside of regular service and fluid changes. He also meticulously maintains his equipment and it gets washed every time it's used.
    From personal experience, we have 5 different Deeres at work. They are all 5065 and 5085. They all get abused and misused. They go long periods between services, usually just getting their oil topped off and air filters changed regularly. We run them in deep, loose, sand. They get run in the salt air and sometimes in the salt water. These tractors have no issues that aren't expected or a product of the abuse they go through. We keep all the electronics, harnesses, and wires coated in marine-grade anti-corrosive sprays. We keep them sprayed down with salt-x to slow the corrosion. Deere dealers are common place and usually not to far away.
    If I was going to buy a compact tractor for my property tomorrow it would be a Deere or Kubota.
  7. Sep 27, 2017 at 5:33 AM
    Kubota would be my first choice, that is for sure. We run them at work and have had zero issues, and our (5) have 3200+ hours on them. Great machines if you take care of them.
    Some good advice, keep the stories and experiences coming.
    Patriot and Pudge like this.
  8. Sep 27, 2017 at 5:53 AM
    NWHmoob
    NWHmoob New Member
    2014 Tundra SR5 DC TRD Offroad
    We have a 10 acre lot that's NOT flat. We bought a 25hp Kubota thinking that was going to be enough to fit our needs. We are wrong. It's under-power and not capable of doing what I need it to do. Since it's fall/winter we can't do much anyways with the incoming weather. We'll be upgrading to a 50+hp next spring. For 2-5 acres of flat land a 25hp tractor will suffice, maybe. Like others have said accessibility to service and parts will play a huge role in what brand you buy.
    Booney and ColoradoTJ[OP] like this.
  9. Sep 27, 2017 at 5:57 AM
    pbryant44
    pbryant44 New Member
    Panama city florida
    2016 tundra 4wd sr5 tss
    I grew up on a small farm in Maine so we used tractors all the time for snow removal and of course chores. My personal favorite was a John Deere 1050 with a bucket which was a 40 hp diesel midsized tractor that fit in the garage for maintenance and was small enough to get around trees that where trimmed. It was large enough to run a bush hog and haul hay wagons and so on. A 4wd tractor is a must for snow removal. Look at snowblower attatchments for the 3pt hitch. Kobota and John Deere are my first two picks. But ultimately I would go with a dealer that's close to your house has a good reputation and has a tractor that fits your needs.
  10. Sep 27, 2017 at 6:00 AM
    That is what I'm looking for. I planned on going with the L-Series Kubota, so power is 33-62 hp. Personally, in my life, I have never thought to myself "I wish I had less HP/TQ", so that is a concern for me as well.
    Thanks for the input.
    Pudge likes this.
  11. Sep 27, 2017 at 6:03 AM
    I have all the major brands right in town, so that is a big plus for us.
    On a tractor, with bucket attachment, I'm trying to stay in the weight limits of my equipment hauler, so under 11000 lbs.
  12. Sep 27, 2017 at 6:12 AM
    NWHmoob
    NWHmoob New Member
    "It's better to have it and not need it then to need it and not have it" -unknown
    Prepare to spend money on implements/attachments; tiller, mower, box blade, etc. Never buy new. In a few days of usage it will look like a used one anyways. Plus, these thing were made to take a beating. If it's worn take a angle grinder to it and it'll be as good as new or just replace it. If you have a lot of blackberry bushes like me dont get a brush hog/rotary mower, get a flail mower as that will mulch everything.
  13. Sep 27, 2017 at 6:15 AM
    I have noticed a huge market in used attachments, for damn good prices. Good suggestion and advice. Thanks.
  14. Sep 27, 2017 at 6:18 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    A cab is a huge plus if you're doing snow removal, factory installed is a lot nicer than aftermarket.
    justfortun and ColoradoTJ[OP] like this.
  15. Sep 27, 2017 at 6:21 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Is say Kubota, with absolute minimum 30hp.
    Rear mounted 3 pt mower, not a belly mower.
    Front bucket that isn't oversized, and make or buy some fork attachments for it for moving pallets and what not.
    Not sure if you'd ever need a backhoe attachment, but from my experience and knowledge, you'd be better off getting a mini excavator with plow blade if you will be doing that kinda stuff often. But they are fine for occasional use
  16. Sep 27, 2017 at 6:22 AM
    That is for sure. Snow removal is a seasonal issue for me. Most of the time it will be used for road repairs jobs.
  17. Sep 27, 2017 at 6:32 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I'm a big fan of Kubota myself. They're built heavy duty and reliable, have a nice seat and cost less than the comparable JD. They're also pretty simple to drive and operate.
  18. Sep 27, 2017 at 6:36 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Bonus points for factory cab is that most usually have heat and A/C. Seems frivolous but when it's 95 degrees it's pretty nice lol.
  19. Sep 27, 2017 at 6:43 AM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    I only have an acre of land, but you guys are really making me want to buy a tractor. Also making me really wish the wife and I had bought the 35 acre horse farm we were looking at last year. It was a killer deal, but we couldn't commit to the amount of work it was going to be to get it back into shape. I drive by it every day on the way to work, and kick myself in the ass for not buying it.
    ColoradoTJ[OP] and zcarpenter92 like this.
  20. Sep 27, 2017 at 6:53 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Buy a Big Bud.....your neighbors would be impressed :thumbsup::rofl:
  21. Sep 27, 2017 at 6:54 AM
    whiteTRD'02
    whiteTRD'02 New Member
    Hardly used is good imo.
    fe8f1cc3f5871479dba084f33ebfbdcb_0ac6a641a353e2bdd0026e1de0e967133988b5e7.jpgabc7d6d88cecb9168e06c7e9cc716db2_86b25802550cfea5a587f0a43170fc4dd258ef66.jpg
    These 2 work great for the driveway, here. Can't just have 1 in the winter in case it breaks. This pair wouldn't be worth the price of a new truck, but they are invaluable to us.
    The little atc saves them a fair bit of running.
    The green 1020 is a '69 & the 350 crawler is a '76. Hopefully that fuels your thoughts. Good luck!
    Florida AF, SC_Mike, mdavis and 2 others like this.
  22. Sep 27, 2017 at 7:38 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  23. Sep 27, 2017 at 8:21 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hey Chris, I have a Mahindra 22. Sometimes I feel it's a little under powered but I manage fine and don't want to store /pay for a larger tractor. It's a couple years old and the only problems I've had are the tach and fuel gauge aren't working and a bolt fell out of one of the backhoe controls.
    I found a rats nest on top of the engine (now I keep cotton balls with peppermint oil under the hood) which coincides with the tach/ fuel gauge failure though I haven't been able to find a chewed wire or blown fuse. The bolt replacement for the backhoe is simple, I just haven't done it yet.
    Like @Pudge said, forks would be really useful at time. For road work you'll want a box scraper, my neighbor and I share one we got on CL for $400. I use the backhoe A LOT and my hands and shovels are thankful.
    The tractor sees more work than I had imagined. I dug out our private road last winter after a slide which more than paid my road association dues for the year. I also helped a neighbor prep an area for his water tanks and prepped an area for our new mailbox location. For about 16k it's turned out to be a great investment.
  24. Sep 27, 2017 at 8:28 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    I think the first question is what horsepower range are you looking at? It appears you want to tinker with a compact size. I run a lot of different tractors for work. I think the smallest horsepower ive ran is around 60, which is probably going to be a lot larger than you need. However, Kubota would be my first choice. Great working mans tractor with large dealer support. Deere is just flat out pricey. That green paint isn't cheap. A great thing about compact tractors is that their loader hookups share a lot of skid steer attachments. So buckets, forks, snow blowers etc are easily accessible. I wouldn't even mesas with mahindra, yanmar, LS or Kioti... but that is just me.
    zcarpenter92 and ColoradoTJ[OP] like this.
  25. Sep 27, 2017 at 9:18 AM
    TXMiamiFan
    Jose
    And I'm Mexican, so you know we will kick some ass!
  26. Sep 27, 2017 at 11:00 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Tractors are only good for one thing. Chicken.
  27. Sep 27, 2017 at 12:23 PM
    This is what I'm looking at for a minimum.
    https://m.kubota.com/Product/Index/223/model
  28. Sep 27, 2017 at 1:40 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    My parents bought a brand new John Deere 3320 (33 horse) back in 2006. Been an awesome tractor with nothing going wrong with it. It has 930 hours. Anything bigger would just be too much for everyday home use. I actually have it at my house for a 5 day weekend right now.
    Ran over a yellow jacket nest first thing this morning. FML!
  29. Sep 27, 2017 at 2:03 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    Good joke. They bigger the better. I think he needs a cabbed 5100E.
    mdavis[QUOTED] likes this.
  30. Sep 27, 2017 at 2:08 PM
    mdavis
    Michael
    Rock Hill, SC
    Meh, not for 2 to 5 acres.
    NewImprovedRon likes this.
