Traction or stability control kicks in on on/off ramps even if I’m not going too fast
Discussion in '2nd Gen Tundras (2007-2013)' started by Yoda111, Dec 5, 2018.
  1. Dec 5, 2018 at 5:37 PM
    Yoda111
    Yoda111 [OP] New Member
    Hey guys,
    So I find my TCS and STability control tend to kick in when I’m going around corners, like on/ off ramps. Sometimes it will go off even if I’m going at a slow speed of 60km/hour. But sometimes it won’t either.
    Also, it feels like my abs kick in too fast. Almost like everything is a bit sensitive.
    I was wondering if having a 3 inch lift and 35’sx12.5’s on it would cause this to happen? And if so, would installing a tuner fix this issue
    Thanks in advanced
  2. Dec 5, 2018 at 5:41 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Black Wolf likes this.
  3. Dec 5, 2018 at 5:48 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  4. Dec 5, 2018 at 6:23 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not sure about a tuner, but my trac goes off if I go too fast around corners also
    TheBeast likes this.
  5. Dec 7, 2018 at 8:52 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Nanny stops the cornering fun for me also. Until I turn it off...;-)>
    B
  6. Dec 7, 2018 at 8:57 AM
    15whtrd
    15whtrd Mr. Blonde
    A tuner is not going to fix that. I want to say it’s possible you need to do a zero point calibration. Also make sure your tires aren’t over inflated.
    Yoda111[OP], gosolo and TheBeast like this.
  7. Dec 7, 2018 at 8:12 PM
    taylor36
    taylor36 New Member
    Taylor
    07 White Tundra 4D Limited 5.7L 4WD
    Bilstein 5100 on all four corners fronts on highest clip position
    What is a zero point calibration?? Never heard this term before
  8. Dec 7, 2018 at 8:36 PM
    15whtrd
    15whtrd Mr. Blonde
    It seems that when you lift a truck, sometimes the nannies go haywire and need to be zeroed out again. At Least this is my understanding of it. Pretty sure there is a paper clip method, or you take it to the dealer and give them 100 bucks LOL. Or a tech stream.
