Traction control problem?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, Jun 20, 2018.
  1. Jun 20, 2018 at 6:51 PM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    My Traction control light was flashing and truck wouldn’t put down power. I was just driving out of my neighborhood at under 20 mph. It was on dry pavement. I stopped, put it in park, restarted and everything was fine.
    Has anyone run across this before?
    It’s a 2014 4wd crewcab with only 39k. No lift, no mods other than cosmetic.
  2. Jun 20, 2018 at 8:51 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    check for rodent damage around the wheels (Anti lock brakes) and under the hood. If you find rat droppings then you may have a damaged wire somewhere...
    831Tun likes this.
  3. Jun 20, 2018 at 9:00 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Check ABS sensor too, I hate that shit it’s so sensitive sometimes when I’m out wheelin what you explained happens but I know it’s the friggin ABS clitoris. I need the SDHQ abs guards.
