Traction control light won’t turn off
Discussion in '2.5 Gen Tundras (2014-2021)' started by Michealmyers99, Oct 9, 2023.
  1. Oct 9, 2023 at 8:17 PM
    Michealmyers99
    Michealmyers99 [OP] New Member
    2015 Tundra
    Tried several ways of getting it to turn off but nothing seems to work. Is there something else to check related to this? No other lights are on
  2. Oct 9, 2023 at 9:42 PM
    Is it in 4wd? Maybe a wheel speed sensor has gone bad?
  3. Oct 10, 2023 at 3:45 AM
    blenton
    blenton New Member
    If it is a 4wd, will it engage? If a wheel
    Speed sensor is bad, if typically won’t shift in to 4wd while running; you have to turn the truck off, move the selector switch, turn the key to on, let it shift, then start it. Same
    To get it back to 2wd. But there are also usually more than just the traction control light illuminated.
