Traction control issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by dnewell, Jul 20, 2023.
  1. Jul 20, 2023 at 6:57 PM
    dnewell
    dnewell [OP] New Member
    I have a 2014 tundra. 250,000 miles. The last few months my traction control light comes on. I have no power when it does. It does it so randomly that mechanics can’t make it so it so they can’t diagnose the problem. Wiring looks ok on sensors. Can’t see anything physically wrong. Any ideas what it might be?
  2. Jul 20, 2023 at 7:09 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    ABS module could be faulty...
    ColoradoTJ likes this.
  3. Jul 20, 2023 at 7:15 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Try asking your question in the General or 2.5 Gen forums. Not everyone watches this Intro forum.
  4. Jul 20, 2023 at 8:04 PM
    Thread moved for exposure.
    texasrho83 likes this.
  5. Jul 20, 2023 at 8:07 PM
    How are your shocks and tires? When the tires on my Lexus get a little more worn my traction control light goes off a lot and kills engine power.
  6. Jul 21, 2023 at 4:33 AM
    dnewell
    Tires and shocks are new. May pull wheels off and make sure everything looks good as far as brakes and shocks go. Thanks for advising.
  7. Jul 21, 2023 at 5:20 AM
    mgxsequioa
    mgxsequioa New Member
    I had a similar issue with my 01 Sequoia that was related to the yaw rate sensor. Unfortunately I don’t recall how it was detected.
    Hopefully I’m not sending you down a bad path. My issue only presented in the heat, never in the winter.
    dnewell[OP] likes this.
  8. Jul 21, 2023 at 9:05 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    When my ABS module went out, the BRAKE, VSC and ABS light went on. It often is intermittent and then eventually fully goes out, if it is the module. You can pull the module off the pump and either test and resolder the connections yourself or send it to a shop for ~100-150 to repair. There are shops on eBay that specialize in the repairs.
    However, since only his traction control is going off, I'm thinking it might be wheel speed sensor related or maybe the yaw rate sensor like the previous poster mentioned. I'd start checking the wiring.
  9. Jul 21, 2023 at 10:08 AM
    dnewell
    Thank you. Great feedback. I will start checking.
