Traction Control Abs and 4 hi/lo lights issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Cbetancourt76, Mar 2, 2019.
  1. Mar 2, 2019 at 9:16 PM
    Cbetancourt76
    Cbetancourt76 [OP] New Member
    Carlos
    2011 Tundra 4x4
    does anyboday know the cause of this? One day I turned on truck and drive out of gas station then I felt the traction control kick on and made my truck drive slow so I turned off then same happened again. After that truck started and turned off took two more tries then I started driving and all those lights came. 4 wheel won’t engage unless I turn truck on first then put into 4hi/lo. Also when I’m first driving before the 4hi/lo lights come on the speedometer doesn’t register correct speed. Only after lights for 4 hi/lo start flashing on and off. I have 2011 4.6 Texas Editon. Please help
  2. Mar 10, 2019 at 4:56 PM
    Judson5.7
    Judson5.7 New Member
    Judson
    2007 Black Tundra SR5 DC 5.7
    Headlights, Front Grille,wheels,seatcovers,brake upgrade, bak flip cover.....
    Hi,
    I had the same issue last month and I found the cause.
    It's the electrical harness connection at the abs module.
    Make sure you have some automotive electrical contact cleaner and some compressed air on hand.
    1)Disconnect the negative battery terminal.
    2)Remove cover and lift upwards on the abs module connector lock and remove it from the module.
    It takes a bit of wiggling but you can get it off.
    3)Blow out both the connector and module pins with the compressed air.
    4)Spray the connector and pins with the electrical contact cleaner.
    5)After about 2-3 minutes, blow dry with the compressed air.
    6)Reinstall the connector and replace the cover.
    7)Reconnect the battery.
    You will have to drive for about a day or two for the engine computer to relearn and bring things like the idle back to normal.
    Hope this helps!!
    LA184 likes this.
  3. Mar 10, 2019 at 5:03 PM
    Cbetancourt76
    Carlos
    2011 Tundra 4x4
    Where do I find abs module?
    Thanks for the help!
  4. Mar 10, 2019 at 5:21 PM
    Judson5.7
    Judson
  5. Mar 10, 2019 at 6:44 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    4hi and 4lo flashing with traction and ABS lights on means transfer case shift failure
  6. Aug 24, 2024 at 4:46 PM
    TonyF
    TonyF New Member
    Tony
    2012 Tundra 4x4
    Had similar issue on 2012 Tundra 4x4 with 200K miles. Ran my scanner with ABS code abilities on the vehicle (Innova 5610) and it said Left Rear wheel sensor bad. Funny thing is the live data showed the sensor was correctly reading wheel speed. Did not detect any wiring damage so I replaced the sensor for about $30. Problem solved.
