Trac off, check engine light on and 4 LO flashing
Discussion in '2nd Gen Tundras (2007-2013)' started by eb85, Nov 6, 2021.
  1. Nov 6, 2021 at 10:54 PM
    eb85
    eb85 [OP] New Member
    13’ tundra
    Afe intake and air aid throttle body spacer. True dual flow master 50 exhaust
    What’s up everyone? Just joined the forum. Have a 2013 tundra and installed an afe cold air intake on it and love it. Installed a air aid throttle body spaced and after driving the truck for about 6 miles, got in it to turn the engine over and fired up fine but had the check engine light on, TRAC Off lit up and 4 LO flashing. Anyone come across this issue at all?
  2. Nov 6, 2021 at 11:02 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    eb85[OP] likes this.
  3. Nov 6, 2021 at 11:07 PM
    eb85
    13’ tundra
    Thank you so much for the info. And reply with the link! Much appreciated! I’ll look into the codes but I have a feeling that throttle body spacer the truck didn’t like
  4. Nov 7, 2021 at 9:26 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  5. Nov 9, 2021 at 2:19 AM
    Jaybird9024
    Jaybird9024 New Member
    2010 Tundra
    I had the EXACT same thing happen. Went to the auto parts store and had them read the codes. I had “lean fuel” on both banks. Seemed unusual to suspect the exhaust so I looked at the intake. After more research I found someone recommended ding I clean the MAF sensor in the intake. Plus they recommended a good battery post cleaning. I bought MAF cleaner and used 1/2 small can on the sensor. Then I let it dry while I serviced the battery.
    So far so good. I only put about 50 miles in the truck and the issue had not returned.
  6. Mar 2, 2023 at 5:37 AM
    dnath28
    dnath28 New Member
    Here is my current situation. The lights flashing on VSC OFF and 4Lo. On lights are everything else you see.
    I have no idea where to start. I recently took off my 4Hi actuator (it was flashing on dash) and unjammed the motor and reinstalled. 4Hi still doesn’t work (reason for me doing the actuator) but the flashing stopped. Now all these lights pop up after driving 40 miles (i disconnected battery after doing work)
  7. Mar 2, 2023 at 5:41 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Go get yer codes scanned
  8. Jun 1, 2024 at 7:34 AM
    xxchicagobadboyxx
    xxchicagobadboyxx New Member
  9. Jun 1, 2024 at 2:22 PM
    bikedennis
    bikedennis New Member
    Dennis
    2007 Tundra 5.7L 4WD
    I got the same issue. Lights came on yesterday ( VCS off and 4lo flashing, traction and CEL on) after pulling a log. I'll start by reading the codes and then disconnecting the battery. I hope it's an easy fix.
  10. Jun 2, 2024 at 5:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Have you tried re installing original parts? Throttle body spacers don't do anything on a NA vehicle.
