TPMS.
Discussion in 'Wheels & Tires' started by RICHIEUSMC, Aug 28, 2020.
  1. Aug 28, 2020 at 3:06 PM
    RICHIEUSMC
    RICHIEUSMC [OP] New Member
    Spring Hill Florida
    2020 Tundra SR5 Double Cab 4x4
    Anyone had one of these break ? Had one break today. I've had my 2020 SR5 Double Cab for about 3 weeks. Called Toyota there going to check/repair it in the morning. I asked if it was covered. They told me they had to look at it first and see what caused it to break. SMH..
  2. Aug 28, 2020 at 4:46 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You have to be careful when you’re cleaning the wheels. They are aluminum and not flexible rubber like a standard valve. So if you bump them to hard when cleaning the wheel you can crack them. Been there already, unfortunately haha.
    RICHIEUSMC[OP] likes this.
  3. Aug 28, 2020 at 5:29 PM
    Rlawshe1
    Rlawshe1 New Member
    Rob
    2020 MGM
    And the sensor can easily be broken while dismounting/mounting a tire while doing a flat repair - I can understand them having to see it before giving you an answer
  4. Aug 29, 2020 at 4:46 AM
    RICHIEUSMC
    Spring Hill Florida
    At toyota now. The service manager said there not covered said it will cost me $300 plus to get it replaced. Or $30 for rubber stem and ill have the air pressure light on. Sucks on a 2 week old truck. I told them to put the rubber stem on. Getting aftermarket wheels soon. Deal with it then. Don't think the spare has a sensor to swap .. ill find out soon.
  5. Aug 29, 2020 at 6:34 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    $300?! Hope you told them to put down the crack pipe...
  6. Aug 29, 2020 at 2:43 PM
    RICHIEUSMC
    Spring Hill Florida
    Yea definitely told them thats not gonna happen. Ya would think that the spare had one. NOT. Told them to just put a rubber stem on it. And since i only had the truck 3 weeks it shouldn't have been a warranty issue. Shouldve just been replace it and call it a day ....wont be going back to Sun Toyota. Aftermarket wheels coming soon...
    glowblue[QUOTED] likes this.
  7. Aug 29, 2020 at 3:29 PM
    glowblue
    VA
    Good for you. I’d file a complaint with Toyota Corporate about a shitty dealer. That’s what I did with my Ford dealer. They didn’t like that I filed a complaint - the dealer GM called me to ask why I complained to Ford...he ate some crow that day!
  8. Aug 31, 2020 at 6:59 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
  9. Sep 1, 2020 at 2:30 AM
    Rlawshe1
    Rlawshe1 New Member
    Rob
    2020 MGM
    The service kit usually consists of the valve core (nickel plated), valve cap, the rubber seals/grommets that seal the sensor in the valve stem hole in the wheel, and a washer or 2 if needed. You will absolutely need this if it doesn’t come with the sensor
  10. Sep 1, 2020 at 5:01 AM
    timsp8
    NY
    Most of the $300 was probably parts. If you ever want it, you’ll have to eventually buy it when you get aftermarket wheels. There might be a cheaper aftermarket sensor though.
    I think the dealer could’ve said they didn’t find any road damage and warrantied it.
  11. Sep 1, 2020 at 11:29 AM
    RICHIEUSMC
    Spring Hill Florida
    There was no road damage. They could've easily taken care of it. They chose not to. But I agree. I'm going to have to buy it. Don't like seeing the indicator light on. Especially on a brand new truck. Ill do it when I have the aftermarket wheels installed. Think some aftermarkets come with sensors.
  12. Sep 1, 2020 at 11:34 AM
    timsp8
    NY
    Yeah that what I was getting at. For such a small price, they could’ve told Toyota anything and warrantied it.
    My radiator got a leak on my 18. Went to the dealer and they said they’ll look at it and if there was road damage then I’d have to pay. Kinda upset me, but I get it. If there was a stick in it then obviously it wasn’t Toyota’s fault. They put no damage found on the repair slip and covered it under warranty.
  13. Sep 1, 2020 at 11:34 AM
    Danman34
    Danman34 New Member
    Danny
    Aftermarket wheel and tire packages don’t come with sensors unless you buy all 4 sensors. Why not just buy one oem sensor and simply swap them into your aftermarket wheels? Oem are far better than aftermarket anyway.
