TPMS
Discussion in 'Wheels & Tires' started by Borko, May 17, 2018.
  1. May 17, 2018 at 12:06 PM
    Borko
    Borko [OP] New Member
    Boris
    Tundra SR5 4x2 2008
    I have Tundra 2008 and after replacing old 18" rims with 20" tire presure lights is on and no one can help with this problem. Any idea. Tnx
  2. May 17, 2018 at 2:09 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Had the same happen to me when I went from 20” to 18” rims. TPMS light came on a day or two after the switch. I took it back to the shop (Discount Tire), and they fixed it. Apparently, one of the sensors got loose or damaged upon install according to them. Might want to take yours back, too, and have them take a look, unless you installed the tires yourself?
  3. May 17, 2018 at 2:16 PM
    Borko
    Boris
    Tundra SR5 4x2 2008
    I was there today and they check all of them 4. They are Ok they try to reset twice and does not work. I have the original tpms do you think if I put back on new rims comp. will recognise and fix the problem . Tnx
  4. May 17, 2018 at 2:32 PM
    equin
    Ed
    DFW, TX
    Unfortunately, I don’t know enough about TPMS to give an answer. Hopefully someone on here with more experience will chime in to assist.
  5. May 17, 2018 at 2:33 PM
    Borko
    Boris
    Tundra SR5 4x2 2008
    Anyway tnx.
  6. May 17, 2018 at 3:04 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Boris, you could try a rebuild kit for your old one's or bite the bullet and order new one's. Hopefully a TPMS expert will help ta out. Good luck:thumbsup:
    equin likes this.
  7. May 17, 2018 at 3:40 PM
    Borko
    Boris
    Tundra SR5 4x2 2008
    Tnx I will try
    rons23 likes this.
