TPMS, yay or nay?
Discussion in 'Wheels & Tires' started by smslavin, Aug 3, 2017.
  1. Aug 3, 2017 at 11:53 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Headed over to Discount Tire to have tires mounted on wheels. Debating on whether or not I want to install TPMS on the new shoes. If I'm aired down and cruising around the boonies, is there a way to shut it off or will I just have to look at the warnings? Skip it or have them put in?
  2. Aug 3, 2017 at 11:56 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    If you skip it you will have the tpms warning on all the time, not just when you are aired down.
    NewImprovedRon and smslavin[OP] like this.
  3. Aug 3, 2017 at 12:25 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you get them, haggle the price down to like $30 per sensor. Don't pay the $60 they be trying to charge you.
    smslavin[OP] likes this.
  4. Aug 3, 2017 at 2:38 PM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    In my 4runner I wired up a switch to toggle it on and off, was a pretty easy mod. You just had to splice a wire.
    Achuop and smslavin[OP] like this.
  5. Aug 3, 2017 at 4:45 PM
    smslavin
    Hudson Valley
    Some stuff
    Would love some info on that if you have it handy
  6. Aug 3, 2017 at 6:35 PM
    motorswin
    motorswin Back the blue
    2017 Tundra Limited TRD
    Maxtrac 3.5" lift Kmc Grenades with Cooper St Maxx 295/75/18
    The sensor is annoying. Get the tpms put in
  7. Aug 4, 2017 at 10:05 AM
    TeeTundraTom
    TeeTundraTom New Member
    2017 black SR Short cab/long bed
    I took the sensors that came with the truck out and sealed them up in PVC pipe. Take a four a five inch section of three inch pipe and two caps to cement over each end. Drilled a hole in one end cap to stick one of the valve stems through to air the canister it up. Throw your sensors in, glue your ends on with the sensors inside and air it up when the glues sets up. Viola TPMS light is always out! Of course your'e only monitoring the air pressure in the canister.
    smslavin[OP] and Blain like this.
  8. Aug 11, 2017 at 1:21 AM
    d0zer
    2017 MGM Platinum
    After I posed this, I looked at how the tundra manages the TPMS, and it is a bit different in GEN2/3. With the 4Runner (GEN4) you simply had to ground the signal wire. It looks like in the newer tundras you have to provide some voltage to trick it. Looks like some people tapped into a 12v always hot line and reduced it to ~5v.
    smslavin[QUOTED][OP] likes this.
