TPMS sensors
Discussion in '1st Gen Tundras (2000-2006)' started by SharkDog, Mar 22, 2021.
  1. Mar 22, 2021 at 9:34 AM
    SharkDog
    SharkDog [OP] New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Hey Crew. I put winter tires on my stock wheels last fall and I think I am going to buy a second set of rims to mount the summer tread. They will likely be snowflakes from a newer 4runner. I'll get some TRDs if I find a decent deal, but they don't seem like they are worth an extra $600 for my use.
    Do the factory TPMS from a newer 4runner included with a used set of rims work with a 2006 tundra? If they don't, my options are ~$40-50 per sensor for new ones? What happens if I don't have any? Is the light on constantly?
    Thanks. This is my first fancy vehicle with tire pressure reporting.
  2. Mar 22, 2021 at 10:08 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If you don't have any you'll be better off and yes, light will remain on constantly UNLESS you cover it with tape OR by cutting a particular wire. Add it to your list of checking condition of tires and purchase decent air gauge, The ole girl will appreciate ya. Hopefully others can help with wire color and other suggestions !
  3. Mar 22, 2021 at 10:15 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You shouldn’t have TPMS. It wasn’t required on all vehicles until 2008.
    Do you know if you do have it for sure? I haven’t heard of Toyota pre-empting the requirement, but I don’t know for sure since mine is an 02.
  4. Mar 22, 2021 at 10:37 AM
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    I bought a set of new Denso sensors but never used them because Costco uses their own sensors (I had bought new wheels). They said they would not take responsibility if they could not program my sensors. I'll sell them to you the Densos for less than I bought them...
    YardBird likes this.
  5. Mar 22, 2021 at 10:43 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    The TPMS light on my 06 DC Limited has been blinking for a year or two
  6. Mar 22, 2021 at 10:58 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Just went through this myself. Apparently this truck requires sensors in the spare tire along with the others. The process of registering them with the ECU is also different from most vehicles. It drove my tire shop nuts, but they finally got it accomplished. Blinking means some of the sensors are dead.
  7. Mar 22, 2021 at 9:12 PM
    SharkDog
    Denver
    I know when I had a slow leak the light would come on.
  8. Mar 22, 2021 at 9:13 PM
    SharkDog
    Denver
    Thanks. I’ll let you know what direction I go.
  9. Mar 22, 2021 at 9:19 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    They are a pain, but useful. I had one die (battery) after 10-12 years. 2 years of that damn light, I had my shop replace them all at 75 a pop. 2 of 5 new ones were dead on arrival, but I don't think they were OEM. Shop ordered 5 Toyota and after a bitch of programming, all good.
  10. Mar 23, 2021 at 11:07 AM
    SharkDog
    Denver
    that doesn’t sound fun. You do the programming or the shop did?
  11. Mar 23, 2021 at 4:43 PM
    alb1k
    Left Coast
    It's good
    Shop did, not fun for them either....
  12. Mar 23, 2021 at 4:47 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I have TPMS on my 2005 RCLB Work Truck ~ may not have been required until 2008 but was included on my Tundra in 2005.
  13. Mar 23, 2021 at 4:57 PM
    Jack McCarthy
    Bill
    North of Boston
    I’m guessing it probably started in 05 since the Tundra changed quite a bit in that year.
    YardBird[QUOTED] likes this.
  14. Mar 23, 2021 at 5:06 PM
    alb1k
    Left Coast
    It's good
    Same, 2005 DC. I think they are worth it. Ever see what happens with low tire pressure at 70mph?
