TPMS sensors
Discussion in 'Wheels & Tires' started by 2024 SR5 crewmax 4x4, Sep 6, 2024.
  1. Sep 6, 2024 at 7:06 PM
    2024 SR5 crewmax 4x4 [OP] New Member
    Hello, everyone
    Please give me an advice or explaination.
    I have just took off 4 original Wheel+Tires and put on 4 W+T from market. Toyota dealership said 4 sensors from market could not reprogram, that is why my truck does not recieve 4 T+W.
    Can I take 4 sonsors from original W+T swap to 4 sensors from market ? toyota service can be do that? and do they need to reprogram or not?
    Thanks for any recommendation
  2. Sep 6, 2024 at 8:08 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    Yes, if you have the original TPMS they can be transferred to the new tires by any tire shop without needing to reprogram anything. Mine were transferred when I got new wheels without any issues
  3. Sep 6, 2024 at 10:17 PM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    Run the tpms "locate sensor position" in the dash menu. Took my truck about 15 minutes/10 miles to find the sensors I put in my aftermarket wheels
  4. Sep 7, 2024 at 2:31 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You need your original or oem sensors. Toyota does not communicate well with aftermarket sensors. Always swap in your oems when getting new wheels. Cost more up front. But saves a lot of heartache
  5. Sep 7, 2024 at 4:46 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
  6. Sep 10, 2024 at 11:32 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I also use TPMS.com, never had a problem with multiple sets of wheels and tires. I use Costco to program them. They usually don't even charge me.
  7. Sep 12, 2024 at 9:35 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
  8. Sep 12, 2024 at 10:45 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I have three sets of wheels that I've had on my truck in the past year or so. Only the OEM set has the OEM tpms sensors. The other two sets of wheels have sensors from Discount Tire. They all work(ed) fine. Like mentioned above, it took 30 minutes to sync up the first time. After that, I never had an issue.
