TPMS Sensor
Discussion in 'Wheels & Tires' started by UTAHRTK, Feb 20, 2023.
  1. Feb 20, 2023 at 8:09 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    At some point my OEM TPMS sensors were replaced by non OEM. I believe this happened at the dealer I purchased from as the truck came with a wheel/tire "upgrade". Recently I had new tires installed and the aftermarket sensors would not allow enough pressure to seat the bead. I am running Method 701s (bead grip) and Toyo R/T Trails. I had the shop remove the sensors... Does anyone know of a capable replacement sensor that will work for a 2017? Thanks.
