TPMS Reset Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Feb 26, 2022.
  1. Feb 26, 2022 at 6:31 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I went to an oversize tire size last year increasing the PSI and was wondering if I need to reset the TMPS. I'm running 44 PSI now and thought the sensors would only warn me if the pressure dropped below 30 PSI or so. Does anyone reset their TPMS for the new pressure? It seems like it should be done.
  2. Feb 26, 2022 at 6:41 AM
    18" TRD Off Road Wheels
    When I adjust pressure I reset the TPMS. Always have to look up the how in the manual though, because it's too infrequent an occurrence for my brain to actually retain it.
    rodl12[OP] likes this.
  3. Feb 26, 2022 at 6:49 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    After you get to your pressure you want hold down the tpms reset. It just adjusts when the light will come on, nothing to do with the actual sensor location or adding a new one
    etc..
    rodl12[QUOTED][OP] likes this.
  4. Feb 26, 2022 at 7:09 AM
    rodl12
    Rod
    South Jersey
    Got it! I do know how to reset it, I just wanted to know if I should do it. I never thought about it when I went to the larger tire and increased the pressure. I checked my pressure the other day and saw it was much lower than when I had check it last summer. I should probably have checked it sooner due to the temperture and season change.
  5. Feb 26, 2022 at 7:13 AM
    parkerbows
    Jack
    Yeah I would. I use this works well and stays charged with solar
    Amazon.com: Tymate Tire Pressure Monitoring System M7-3 - Solar Charge, 5 Alarm Modes, Auto Backlight LCD Display, Auto Sleep Mode, 4 TPMS Sensors (0-87 PSI) : Automotive
