TPMS question?
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Dec 28, 2022.
  1. Dec 28, 2022 at 6:48 AM
    Tb2
    Tb2 [OP] New Member
    James
    I have not so far been able to figure out how to check all 4 tire pressures from the multifunction display .
    I go to setting and tpms move click on it arrow left right up down , but it doesn't show the actual current air pressure reading for each tire .
    what am i doing wrong.
    2022 1794 hybrid crew 4x4 TRD
  2. Dec 28, 2022 at 6:50 AM
    Some times you have to drive a little for the sensors to pick up. At least that's how my 2019 Tundra and my '23 Tacoma have worked. Drive it a mile and they should read.
  3. Dec 28, 2022 at 6:53 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Yup, what he said. It’s not instant read, at least on the 2nd gen. My wife 2020 Lexus also has a delay before it shows pressure.
  4. Dec 28, 2022 at 7:03 AM
    Tb2
    Tb2 [OP] New Member
    James
    I had just drove from work to home 8 miles interstate pulled into garage and starting trying to check it no display of tire pressures
  5. Dec 28, 2022 at 7:06 AM
    pursuit2550
    Time for a dealer visit then. They might have to reprogram them.
  6. Dec 28, 2022 at 7:07 AM
    Huh. Well that is a conundrum. I'm not sure what could cause it unless the sensors might not have been registered to the truck. Has it ever worked? You might try the re-register process that should be in your manual.
  7. Dec 28, 2022 at 7:07 AM
    On previous gens you could do that yourself. No need to pay a dealership or wait on them to get around to it.
    pursuit2550[QUOTED] likes this.
  8. Dec 28, 2022 at 7:09 AM
    pursuit2550
    True, the button under the steering column. Maybe the 3rd gen has something similar.
    GODZILLA[QUOTED] likes this.
  9. Dec 28, 2022 at 7:27 AM
    Tb2
    Tb2 [OP] New Member
    James
    I have never tried to check it before Its only 3 months old. I noticed the tires seemed low cold weather and wanted to check what air pressure was .
  10. Dec 28, 2022 at 7:32 AM
    Then they may not have been synced up. I'd check your manual for the process and see if it's something you can do yourself. If not, you'd probably have to ask your dealership, if you trust them.
  11. Dec 28, 2022 at 8:33 AM
    wildmank99
    wildmank99 New Member
    Arizona
    22 Tundra Limited
    I know that I just did new wheels and tires and when i reset them it took a little bit of driving for them to reg the new ones.
